Switch Default-Gateway Question
rayroyaleverest
How do I observer the default-gateway set on a switch? I am not able to view it with the "show running-config" command.
3 Accepted Solutions
mahmoodmkl
Level 7
Level 7
show running-config should list it.Check weather it is configured in the switch.
Btw what kind of this switch is.
Mahmood
You should fing "ip default-gateway" in the config.
you can also have a IP route 0.0.0.0 0.0.0.0 entry if ip routing is enable.
The last possibility, (if the switch is working and no default gateway configure), is that the router is doing proxy-arp. This is a security issue but still possible.
glen.grant
Use the command "show ip default " , this will list the gateway on all layer 2 switches and any layer 3 switch that has routing turned off .
10 Replies 10
dominic.caron
Level 5
Level 5
What type of switch is it...CatOS or IOS
The switch type is IOS.
mahmoodmkl
Level 7
Level 7
Mahmood
This is a Catalyst 2950 switch.
2950 is a layer two switch , so IP route is not supported.
~JG
The IP default-gateway should be supported for telnet to other subnets.
Yes, that is supported.
glen.grant
The command "show ip" lists the switch ip address, subnet mask, and default gateway.
