Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Switch down: Cable put between 2 ports
What can be done if someone put a cable between 2 ports on a switch and cause a switch to be down. Yes, we can disable the port but is there an another way to block the loop ?
switchport port-security could be useful ? Or maybe the switchport protected ?
interface FastEthernet0/22
description RTIS_SSN
switchport access vlan 172
storm-control broadcast level 80.00
storm-control multicast level 80.00
storm-control unicast level 80.00
storm-control action shutdown
storm-control action trap
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
interface FastEthernet0/23
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 172 (VLAN0172)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switchport: Enabled
Voice VLAN: none
Protected: false
Re: Switch down: Cable put between 2 ports
Your config seems to have most of the configs to block a physical loop. BPDU Guard will do the job in this kind of issues.You can use sport security on a scenario in which some conects a switch whic wont send any BPDU's (I once faced a similar physical loop when we used a D-link L2 switch to extend out conf room LAN).So you can add port security as an additional step of security to limit the num of MAC limited on each port.
Ullas
The broadcast or loop will increment the number of MAC address on a single port ?
I suggest to disable non-used port and maybe implement switchport protected between active ports who doesn't talk each other.
I think the person want to be sure that no bad cable will be plug in the switch and put the switch A down.
I read that the bpdufilter takes precedence over the bpduguard feature so, the bpduguard do nothing in this situation.
I will suggest to disable bpdufilter and set the non-used port in disable state, switchport mode access. Maybe implement errdisable feature too.
Hall of Fame Super Silver
Hello Jonathan,
bpuguard is the right tool in this scenario.
bpufilter can only create loops in this kind of scenario it is a tool for service providers to be used in some cases of L2 transport services to hide SP switches.
So you are in the right track.
For additional security if someone puts its own home switch you can consider to use also port security to put in errordisable ports where more then two mac addresses are learned.
There was another thread about this and I reported here a synthesis of it.
Hope to help
Giuseppe
243
