11-24-2006 07:40 AM - edited 03-05-2019 01:00 PM
Dear all,
I have on my cisco 3550 the following errors on the log:
Nov 24 10:06:07: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to up
Nov 24 10:06:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
Nov 24 10:06:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
Nov 24 10:06:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
Nov 24 10:17:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
Nov 24 10:17:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
Nov 24 10:40:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/36, changed state to down
Nov 24 10:40:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/36, changed state to up
Nov 24 12:59:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/42, changed state to down
Nov 24 12:59:22: %LINK-3-UPDOWN: Interface FastEthernet0/42, changed state to down
Nov 24 12:59:24: %LINK-3-UPDOWN: Interface FastEthernet0/42, changed state to up
Nov 24 12:59:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/42, changed state to up
Nov 24 12:59:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/42, changed state to down
Nov 24 12:59:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/42, changed state to up
Nov 24 14:03:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/3, changed state to down
Nov 24 14:03:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/3, changed state to up
Nov 24 15:28:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to down
Nov 24 15:28:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to up
this error is on the log every minutes.
Could you help me to understand why?
the PC connected to the 3550 are always power on.
Thanks & Regards,
Igor.
11-24-2006 07:43 AM
Hi Igor,
Can you please confirm if all the ports are behaving the same way or only few ports and also can you paste the "sh run" from the switch.
I believe some negotiation problem is causing links to flap? Can you confirm f you have hard coded the speed and duplex settings on switchport.
Ankur
11-26-2006 11:48 PM
11-27-2006 12:10 AM
Hey Friend,
I got the reason for your switchport flaps. Bydefault all ports on 3550 are in dynamic desirable mode which is creating a flap because dynamic desirable mode negoitates to form a trunk and because the device connected to this does not support trunk it is flapping.
Configure this and you will be good to go
interface FastEthernet0/1
switchport mode access
switchport access
Apply the config for all the ports which are connected to your end stations and it will be stable then.
Ankur
*Pls rate all helpfull post
11-27-2006 07:14 AM
Hi Ankur,
I have done, now i am looking for error on the log, tommorow i write you the results.
Thank & Bye.
Igor.
