Switch Issue[urgent ]
Dear All,
I am getting the below erros messages, could some one help me in fixing up this issue
logs pasted below
09-01-19 12:15:16 Local1.Alert 172.24.11.3 %RTD-1-ADDR_FLAP: FastEthernet0/23 relearning 30 addrs per min
2009-01-19 12:15:17 Local1.Alert 172.24.11.5 %RTD-1-ADDR_FLAP: FastEthernet0/1 relearning 30 addrs per min
2009-01-19 12:16:16 Local1.Alert 172.24.11.3 %RTD-1-ADDR_FLAP: FastEthernet0/23 relearning 30 addrs per min
2009-01-19 12:16:17 Local1.Alert 172.24.11.5 %RTD-1-ADDR_FLAP: FastEthernet0/1 relearning 30 addrs per min
2009-01-19 12:17:16 Local1.Alert 172.24.11.3 %RTD-1-ADDR_FLAP: FastEthernet0/23 relearning 30 addrs per min
2009-01-19 12:17:17 Local1.Alert 172.24.11.5 %RTD-1-ADDR_FLAP: FastEthernet0/1 relearning 30 addrs per min
2009-01-19 12:18:16 Local1.Alert 172.24.11.3 %RTD-1-ADDR_FLAP: FastEthernet0/23 relearning 30 addrs per min
2009-01-19 12:18:17 Local1.Alert 172.24.11.5 %RTD-1-ADDR_FLAP: FastEthernet0/1 relearning 30 addrs per min
2009-01-19 12:19:16 Local1.Alert 172.24.11.3 %RTD-1-ADDR_FLAP: FastEthernet0/23 relearning 30 addrs per min
2009-01-19 12:19:17 Local1.Alert 172.24.11.5 %RTD-1-ADDR_FLAP: FastEthernet0/1 relearning 30 addrs per min
Adhitya
Re: Switch Issue[urgent ]
Hi Adhitya,
Looks like a loop situation, by any chance are you trying to configure etherchannel. if yes have a look at this link -
http://www.cisco.com/en/US/products/hw/switches/ps607/products_configuration_example09186a0080094789.shtml
-> Sushil
The messages u r seeing is of STP Loop check for the redundant links in u r network and disable one of them and check for the issues that caused this.
Mahmood
Look at HSRP State Changes and Switch Reports RTD-1-ADDR_FLAP in Syslog
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml#t4
I hope this helps.
Best regards.
Massimiliano.
Purple
I agree someone has physically looped those 2 ports together . Also do a show cdp neighbor and see if the switch sees itself on both of those ports. For some reason spanning did not take care of the loop .
Dear All
Thanks very much for all who replied quickly
Please note that i am not configuring any ether channel
2) Chekced HSRP and found perfectly working fine
Note:These both ports are both trunk ports
could suggest me more on this
regards
Adhitya
Could any one help me on this poast
Adhitya
Please post output of "sh cdp nei".
Also post running config for both ports.
hi
Please find the output of cdp ne and runing config of ports
Fas 0/17 161 R S I Cisco 2851Gig 0/0.1
SEP00152B1761AB Fas 0/3 175 H Cisco IP PPort 1
SEP0014A9EF0382 Fas 0/8 175 H Cisco IP PPort 1
SEP0014A9CB2187 Fas 0/16 175 H Cisco IP PPort 1
SEP0014A9EDF50A Fas 0/12 175 H Cisco IP PPort 1
SEP0014A98186DB Fas 0/21 145 H Cisco IP PPort 1
SEP0014A9CB238B Fas 0/23 175 H Cisco IP PPort 1
SEP0014A98BCA67 Fas 0/6 175 H Cisco IP PPort 1
SEP0014A9D9C99F Fas 0/11 175 H Cisco IP PPort 1
SEP00152BA21DF1 Fas 0/5 175 H Cisco IP PPort 1
SEP0014A9EF0A89 Fas 0/7 130 H Cisco IP PPort 1
SEP0014A9CB257D Fas 0/9 145 H Cisco IP PPort 1
SEP00152B483CEE Fas 0/2 175 H Cisco IP PPort 1
RS-01 Gig 0/1 164 T S WS-C3524-XGig 0/1
RS-01 Fas 0/1 163 T S WS-C3524-XFas 0/1
DR-02 Fas 0/23 132 T S WS-C3524-XFas 0/1
DR-03 Fas 0/23 155 T S WS-C3524-XFas 0/1
172.24.11.3#sh run int fa0/23
Building configuration...
Current configuration:
interface FastEthernet0/23
switchport mode trunk
no snmp trap link-status
end
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
SEP0014A9CB2382 Fas 0/23 161 H Cisco IP PPort 1
SEP0014A9EDD7E5 Fas 0/11 120 H Cisco IP PPort 1
SEP00152B23BD39 Fas 0/7 131 H Cisco IP PPort 1
SEP0014A9CB238B Fas 0/1 131 H Cisco IP PPort 1
SEP0004f2e05103 Fas 0/22 143 H Cisco IP Cport 1
SEP0014A9EDF391 Fas 0/9 160 H Cisco IP PPort 1
SEP0014A9CB261B Fas 0/6 160 H Cisco IP PPort 1
DR-04 Fas 0/2 132 T S WS-C3524-XFas 0/1
-DR-01 Fas 0/1 168 T S WS-C3524-XFas 0/23
-DR-02 Fas 0/1 148 T S WS-C3524-XFas 0/1
DR-03#sh run int fa0/1
interface FastEthernet0/1
end
Please guide me
Adhitya
Hall of Fame Super Silver
Hello Adhitya,
likely someone has inserted an hub in your network see
you say the two ports f0/1 and f0/23 are trunk ports but we see two CDP neighbors on your fas0/23 this is possible only if an hub or a non Cisco switch is connected to fas0/23 and the two devices DR-02 and DR-03 are then connected to it.
Another device RS-01 is connected to port fas0/1 but here you see only one neighbor.
probably the three switches RS-01, DR-02 and DR-03 are also connected between them
Verify what is connected to your fas0/23 in the switch receiving the error messages if necessary modify the cabling so that you see only one neighbor out port fas0/23
Hope to help
Giuseppe
Silver
In addition to what Giuseppe found, also this can be something.
From your first cdp output the 7:th entry is
and from second cdp output the 4:th entry is
it seems that this is the device which is shortcutting the ports.
/Mikael
Silver
In addition to that, and together with the other details I would think someone plugged the PC-port of the IPphone (SEP0014A9CB238B ) into a hub or non cisco switch, where the switch has an uplink to the network as well.
Unplug the PC-port of the IPphone (SEP0014A9CB238B ) and the loop should be gone.
Hi all
Thanks very much to all for supporting
as suggested in the previous post i have removed the deviceSEP0014A9CB238B from the network but still loop occurs
could some one help
regards
Adhitya
after removing the phone from the port please do a show cdp nei detail would like to see more information on the device that is attached to this port....
Dear All
Please find the our put after removing the phone
DR-01#sh run int fa0/23
end
DR-01#sh cdp n
Fas 0/17 137 R S I Cisco 2851Gig 0/0.1
SEP00152B1761AB Fas 0/3 146 H Cisco IP PPort 1
SEP0014A9EF0382 Fas 0/8 146 H Cisco IP PPort 1
SEP0014A9CB2187 Fas 0/16 146 H Cisco IP PPort 1
SEP0014A9EDF50A Fas 0/12 146 H Cisco IP PPort 1
SEP0014A98186DB Fas 0/21 176 H Cisco IP PPort 1
SEP0014A98BCA67 Fas 0/6 146 H Cisco IP PPort 1
SEP0014A9D9C99F Fas 0/11 146 H Cisco IP PPort 1
SEP00152BA21DF1 Fas 0/5 146 H Cisco IP PPort 1
SEP0014A9EF0A89 Fas 0/7 146 H Cisco IP PPort 1
SEP0014A9CB257D Fas 0/9 176 H Cisco IP PPort 1
SEP00152B483CEE Fas 0/2 146 H Cisco IP PPort 1
RS-01 Gig 0/1 127 T S WS-C3524-XGig 0/1
RS-01 Fas 0/1 126 T S WS-C3524-XFas 0/1
DR-02 Fas 0/23 122 T S WS-C3524-XFas 0/1
DR-03 Fas 0/23 154 T S WS-C3524-XFas 0/1
DR-01#
2 Switch
Jan 23 11:29:31: %RTD-1-ADDR_FLAP: FastEthernet0/1 relearning 30 addrs per min
Jan 23 11:30:31: %RTD-1-ADDR_FLAP: FastEthernet0/1 relearning 30 addrs per min
DR-03# sh run int fa0/1
end
DR-03#sh cdp n
SEP0014A9CB2382 Fas 0/23 170 H Cisco IP PPort 1
SEP0014A9EDD7E5 Fas 0/11 173 H Cisco IP PPort 1
SEP00152B23BD39 Fas 0/7 140 H Cisco IP PPort 1
SEP0004f2e05103 Fas 0/22 159 H Cisco IP Cport 1
SEP0014A9EDF391 Fas 0/9 151 H Cisco IP PPort 1
SEP0014A9CB261B Fas 0/6 170 H Cisco IP PPort 1
DR-04 Fas 0/2 171 T S WS-C3524-XFas 0/1
DR-01 Fas 0/1 145 T S WS-C3524-XFas 0/23
DR-02 Fas 0/1 176 T S WS-C3524-XFas 0/1
DR-03#
Silver
As Giuseppe already pointed out, there still seems to be some kind of equipment(hub) connected between DR01, DR02 and DR03.
DR-01#sh cdp n
DR-03#sh cdp n
If you can provide us with a drawing, showing us how things are connected will help us understand.
Or do sh cdp ne also on RS01, DR02 and DR04
/Mikael
327
