Community Member
switch mac adress
hi,
I have a doubt about switch mac address; either swiych has a mac address or each port has mac address??
Community Member
Re: switch mac adress
I have attached a snapshot taken from packet tracer, in that each port has mac address
but all the vlans share the same mac... i dont understand this
switch mac adress
Hi Vishal,
what you see is expected. vlans share mac addresses (to save resources) as every mac address has to be unique within  every vlan
Riccardo
Community Member
vlan's mac address is virtual mac or physically present on a switch??
It is virtual but it is derived from the physical "Base ethernet MAC Address" of the switch that you can see in show version
Base ethernet MAC Address       : 00:24:50:43:C7:00
lan-3750-1#sh int vlan 1
  Hardware is EtherSVI, address is 0024.5043.c740 (bia 0024.5043.c740)
Riccardo
Community Member
The switch knows what traffic belongs to which VLAN even though it is using the same MAC on each vlan as it tags the traffic so that fact that it uses the same MAC is fine . As Riccardo said it saves resources  .
Community Member
thank u very much!!!
what does bia mean?
switch mac adress
Burned In Address.
Community Member
BIA stands for "Burned In Address" So its basically saying that is the vendor assigned MAC address of your device...at least that is what I belive it to mean
Community Member
Thank you james
1774
