11-23-2013 10:58 PM - edited 03-07-2019 04:45 PM
I have layer 3 switch and I want to manage it through telnet. If I have a SVI with ip address 10.89.22.3 255.255.255.0 will the ip default gateway command work if I want to telnet from another vlan on another switch and also does the ip default gateway ip address needs to be on the same network as 10.89.22.3. Also this layer 3 switch is trunk to another switch that has SVIs configure and running eigrp. Will the ip default gateway ip address be one of the svi ip address on the other switch that is trunk to?
Any Suggestions...
11-24-2013 12:57 AM
You use the ip default-gateway command to set the L3 next-hop from your switch. This device will be responsible for routing packets for remote destinations. It needs to be in the same subnet as the SVI.
If the other switch is the closest L3 hop then use that as the gateway for the other switch. This is from the Config Guide for 2960:
Daniel Dib
CCIE #37149
11-24-2013 07:15 PM
Hi Daniel,
Need to confirm below network design
We have layer 2 switch acting as VTP client and it has SVI and we need to manage the switch via ssh and it has ( ip default-gateway ip address) command and in my case the ip address of default gateway is not directly connected to layer 2 switch is this network design ok?
MAhesh
11-24-2013 10:20 PM
If you have multiple L2 hops, that is fine. As long as you have end to end communication to reach the gateway. If you could provide a digram that would clarify things.
Daniel Dib
CCIE #37149
