Switch model advice
AQUALUNGAMERICA
I have a Cisco 5520 firewall that I want to VLAN connect to a WLC and 5 AP's so I can separate into a inside corporate network and a guest network that will just have access to the Internet. I need a good PoE and layer 3 switch? Any recommenations? I will be connecting the switch and firewall via Gigabit Ethernet cable as I have no fiber module on the ASA.
Thank you
Carlos
Reza Sharifi
You can use a 3560X.  Usually 3560 is cheaper then 3750X if you don't need stacking.
Have a look:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
Reza Sharifi
Have a look:
Reza,
         Thank you for the advice on the 3560. We are good to go here and are proceeding with the purchase and implementation.
Carlos
5 ports only?
Try an 8-port switch.  Do you want PoE or not, you can use the compact (fanless) switch here.
