Switch not detecting connection
Hey everyone,
I feel like I'm missing something really simple here... I'm trying to connect an interface on a module plugged into my 4900M switch. I have the interface activated, but there is no connection, no link lights, no activity whatsoever. It appears that all interfaces on this module are not functioning (the status light is on and green and the switch seems to recognize everything).
The switch is a Cisco Catalyst 4900M
The expansion module is model WS-X4908-10G-RJ45
Current configuration : 3056 bytes
version 15.1
no service pad
service compress-config
hostname labswitch
boot-start-marker
boot system bootflash:cat4500e-entservicesk9-mz.151-1.SG2.bin
boot-end-marker
enable secret 5 $1$Kc9I$61LiJVJa3q8vjXtFHJ/zT1
enable password hackme4fun!
username test privilege 15 password 0 test
username roman password 0 hackme4fun privilege 15
username view
no aaa new-model
ip vrf mgmtVrf
ip domain-name cyber
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
vlan 10
name AARC1
vlan 11
name AARC2
vlan 12
name AARC3
ip tftp source-interface FastEthernet1
ip vrf forwarding mgmtVrf
ip address 192.168.1.29 255.255.255.0
speed auto
duplex auto
interface TenGigabitEthernet1/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface TenGigabitEthernet1/2
switchport access vlan 11
interface TenGigabitEthernet1/3
switchport access vlan 12
interface TenGigabitEthernet1/4
authentication port-control auto
interface TenGigabitEthernet1/5
interface TenGigabitEthernet1/6
interface TenGigabitEthernet1/7
interface TenGigabitEthernet1/8
interface TenGigabitEthernet2/1
interface TenGigabitEthernet2/2
interface TenGigabitEthernet2/3
interface TenGigabitEthernet2/4
interface TenGigabitEthernet2/5
interface TenGigabitEthernet2/6
interface TenGigabitEthernet2/7
interface TenGigabitEthernet2/8
interface GigabitEthernet2/9
interface GigabitEthernet2/10
interface GigabitEthernet2/11
interface GigabitEthernet2/12
interface GigabitEthernet2/13
interface GigabitEthernet2/14
interface GigabitEthernet2/15
interface GigabitEthernet2/16
interface Vlan1
ip address 192.168.1.30 255.255.255.0
interface Vlan10
ip address 10.1.0.1 255.255.0.0
interface Vlan11
ip address 10.2.0.1 255.255.0.0
interface Vlan12
ip address 10.3.0.1 255.255.0.0
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 180 life 360 requests 25
banner motd ^Comans Cyber Lab
Cyber Lab^C
line con 0
stopbits 1
line vty 0 4
password terminal-password
login
line vty 5 15
login
monitor session 1 source interface Te1/3
monitor session 1 destination interface Te1/4
monitor session 1 filter packet-type good rx
end
TenGig1/1-8 are fiber modules plugged into the switch, and are functioning normally.
TenGig2/1-8 refer to physical 10G ethernet ports. Included in this is GI2/9-16. I'm not sure what those are referring to, as the module only has 8 ports and there are no other modules installed... When we remove the module, however, the GI ports dissapear along with TenGig2/1-8
TROUBLESHOOTING STEPS COMPLETED:
Restarted the device
Removed the module/Reinsterted
Changed cable with known functioning CAT6 cable
Attached interface to known functioning network
Assigned interface to VLANS 1 and 12
Attempted to configure GI2/9 with the same configuration of TenGig2/1
Any ideas? Thanks for all of your help in advance!
Hall of Fame Super Gold
The link is a copper link?  Have you done a TDR?
I am not sure if the 4900M supports TDR
Re: Switch not detecting connection
I don't believe the 4900M supports TDR..
I did actually discover what the issue was via this thread: https://supportforums.cisco.com/thread/2177060
Ivan Shirshin
The ports cannot auto negotiate to Gigabit speeds, that is why it shows TenGigabit ports or Gigabit ports.
You can check the current settting for each port group below:
Switch#sho hw-module module 3 port-group
Module Port-group Active                         Inactive
   2        1     Te2/1-2                        Gi2/9-10
   2        2     Te2/3-4                        Gi2/11-12
   2        3     Te2/5-6                        Gi2/13-14
   2        4     Te2/7-8                        Gi2/15-16
The command to change between TenG and Gb modes is "hw-module module 2 port-group 1 select gigabitethernet"
Purple
  These switches have dual speed ports and you have to select what you want use , whether 10 gig or 1 gig . Might be something like that , check out interface config.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/sw_int.html#wp1066964
245
