07-11-2012 12:25 PM - edited 03-07-2019 07:43 AM
Can someone please tell me why the attched config gives me only a Password: prompt when I SSH to it? It originally had a password on line vty 0 4.
Solved! Go to Solution.
07-11-2012 02:36 PM
Under the vty lines add login local:
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
And test again.
07-11-2012 02:36 PM
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
And test again.
07-11-2012 03:58 PM
I use AAA and login authentication admin under line vty 0 4 on all my routers and have never run into this problem. I'll try login local and let you know what happens.
07-11-2012 04:03 PM
This just keeps getting better. The only option for the login command is authentication. No local.
07-11-2012 04:12 PM
OMFG I'm an idiot. The reason I wasn't getting a username prompt when using SSH to get to the switch is because I was coming from a router. The switch was using the router's username so I just needed to supply the password.
