Switches configuration in VMWARE environnement
Is it possible to add some commands to improve VMWARE server connected to Cisco Switches.
The VMWARE Servers use the same card for whole servers on them.
regards,
Re: Switches configuration in VMWARE environnement
Which switch is this ?
You can enable spanning-tree portfast on the the switchports connected to the server. Disable DTP/PAGP negotiations on the ports connected to the server.You can haddcode the speed/duplex on the ports and the serverside if you have any speed/duplex issues.
HTH,
-amit singh
Switches are 2960. The configuration seems to be like you specified. I would like to know if there were specific command thant can be added for VMWARE.
119
