05-28-2010 02:26 PM - edited 03-06-2019 11:19 AM
Hello Experts..
Can anybody help me with this??
CORE-VSS1#sh module switch 1 slot 1
Switch Number: 1 Role: Virtual Switch Active
Mod Ports Card Type Model Serial No.
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1415FERD
Mod MAC addresses Hw Fw Sw Status
1 8843.e11b.2c0c to 8843.e11b.2c0f 3.1 Unknown Unknown PwrDown
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6700-DFC3B SAL1415F70V 4.8 PwrDown
Mod Online Diag Status
1 Not Applicable
CORE-VSS1#sh module switch 1 version
Mod Port Model Serial # Versions
1 4 WS-X6704-10GE SAL1415FERD Hw : 3.1
Fw : unknown
Sw : unknown
Sw1: unknown
WS-F6700-DFC3B SAL1415F70V Hw : 4.8
5 5 VS-S720-10G SAL1413E2QW Hw : 3.2
Fw : 8.5(3)
Sw : 12.2(33)SXI2a
Sw1: c6kfw@0.5.239
VS-F6K-MSFC3 SAL1414EW1S Hw : 2.1
Fw : 12.2(17r)SX6
Sw : 12.2(33)SXI2a
VS-F6K-PFC3C SAL1414ENK4 Hw : 1.1
Why my slot is unknown & powered Down ?? is it because of WS-F6700-DFC3B??
SAT-CORE-VSS1#sh platform hardware pfc mode
PFC operating mode : PFC3C
Configured PFC operating mode : PFC3C
Please help... Do I need to change it to DFC3C?
I have another VSS at ACCESS...
ACCESS-VSS1#sh module switch 1 slot 8
8 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1416FNDS
8 8843.e11b.4ea4 to 8843.e11b.4ea7 3.1 12.2(14r)S5 12.2(33)SXH5 Ok
8 Centralized Forwarding Card WS-F6700-CFC SAL1415FH3P 4.1 Ok
8 Pass
Here it gives me normal...
Thanks & Regards
Mudasir Abbas
Solved! Go to Solution.
05-28-2010 02:40 PM
Hi Mudasir,
What are the ports you are using for VSL links? As per below 6704 is not supported for VSL links.
Virtual switch link (VSL): 10 Gigabit Ethernet connections (up to eight using EtherChannel) between the virtual switch members. The 10 Gigabit Ethernet connections have to be one or more of the following modules:
– Virtual Switching Supervisor 720 10GE: 10 Gigabit Ethernet uplink ports
– WS-X6708-10G module: any 10 Gigabit Ethernet port
– WS-X6716-10G module: only non-oversubscribed ports can be used for VSL (supported with 12.2(33)SXI)
Reza
05-28-2010 02:52 PM
Hello Mudasir,
yes or you put the right type of DFC or you use a CFC
VSS hardware requirements clearly lists this point
Hope to help
Giuseppe
05-30-2010 05:36 AM
Hello Mudasir,
if you refer to second VSS in your first post the 6704 is using a CFC and this is acceptable.
the first VSS shuts down the module for the DFC3B submodule.
If you mean that you have a VSS that hosts a WS-6704 module with a DFC3B and it is up/up that would be strange
>> If any switching module in the VSS is provisioned with DFC3C, the whole VSS must operate in PFC3C mode. If a 67xx series switching module with a DFC3A/3B/3BXL is inserted in the chassis of a VSS, the module will remain unpowered, because VSS supports only DFC3C and DFC3CXL.
see
Hope to help
Giuseppe
05-28-2010 02:40 PM
Hi Mudasir,
Reza
05-28-2010 09:55 PM
Hi Reza,
For now its with Sup720 Tengig ports.
the strange this is x6704 module on one pair of VSS are up and down on the other with same sup
WS-X6716-10G module: only non-oversubscribed ports can be used for VSL (supported with 12.2(33)SXI)?? What
is this mean?
05-29-2010 12:47 PM
Hi Mudasir,
Ok, then may be you just have bad 4 port 10Gig card. Do you have the same type PSU (Watts) on both devices?
Reza
05-30-2010 07:24 AM
Do you have the same type PSU (Watts) on both devices? Yes
05-30-2010 05:36 AM
Hello Mudasir,
see
Hope to help
Giuseppe
05-30-2010 07:22 AM
On Access VSS Switching module is working because It is Centralized Forwarding Card WS-F6700-CFC...
SAT-ACCESS-VSS1#sh module switch 1
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL1414EMLU
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1416FKLW
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1414EKYF
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1416FJ2E
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G SAL1413E5CR
6 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1412DR1L
7 1 Application Control Engine Module ACE20-MOD-K9 SAD1408037L
1 68ef.bd7e.e258 to 68ef.bd7e.e26f 4.3 12.2(18r)S1 12.2(33)SXH5 Ok
2 c47d.4f0b.1a50 to c47d.4f0b.1a7f 3.4 12.2(18r)S1 12.2(33)SXH5 Ok
3 68ef.bde1.4908 to 68ef.bde1.4937 3.4 12.2(18r)S1 12.2(33)SXH5 Ok
4 5475.d024.bb50 to 5475.d024.bb7f 3.4 12.2(18r)S1 12.2(33)SXH5 Ok
5 0025.84bf.a398 to 0025.84bf.a39f 3.2 8.5(3) 12.2(33)SXH5 Ok
6 c47d.4f8a.ff10 to c47d.4f8a.ff3f 3.4 12.2(18r)S1 12.2(33)SXH5 Ok
7 0026.cb89.6908 to 0026.cb89.690f 2.6 Unknown Unknown PwrDown
1 Centralized Forwarding Card WS-F6700-CFC SAL1415FHAN 4.1 Ok
2 Centralized Forwarding Card WS-F6700-CFC SAL1413E7Y0 4.1 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAL1413E51Y 4.1 Ok
4 Centralized Forwarding Card WS-F6700-CFC SAL1413E9GB 4.1 Ok
5 Policy Feature Card 3 VS-F6K-PFC3C SAL1414EV3E 1.1 Ok
5 MSFC3 Daughterboard VS-F6K-MSFC3 SAL1414EN7D 2.1 Ok
6 Centralized Forwarding Card WS-F6700-CFC SAL1413E572 4.1 Ok
On Core VSS it not working because it is 1 Distributed Forwarding Card WS-F6700-DFC3B SAL1415F763 4.8 PwrDown.
Now this Distributed & centralized switching are a hardware features... ??? And can not be changed by IOS.
SAT-CORE-VSS1#sh module switch 2
Switch Number: 2 Role: Virtual Switch Standby
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1414EQ31
2 8 Network Analysis Module WS-SVC-NAM-2-250S SAD140500EW
5 5 Supervisor Engine 720 10GE (Hot) VS-S720-10G SAL1414EFYM
1 68ef.bdff.405c to 68ef.bdff.405f 3.1 Unknown Unknown PwrDown
2 c47d.4fbe.4bd8 to c47d.4fbe.4bdf 1.2 7.2(1) 4.1(1) Ok
5 0026.cb61.1000 to 0026.cb61.1007 3.2 8.5(3) 12.2(33)SXI2 Ok
5 Policy Feature Card 3 VS-F6K-PFC3C SAL1414ELC8 1.1 Ok
5 MSFC3 Daughterboard VS-F6K-MSFC3 SAL1414EW1X 2.1 Ok
1 Not Applicable
2 Pass
5 Pass
Thanks Giuseppe & Reza for your help...
05-28-2010 02:52 PM
Hello Mudasir,
Hope to help
Giuseppe
