Webcast-Catalyst9k
Switchport difference
What is the difference between
interface FastEthernetx/x
no ip address
speed 10
duplex full
spanning-tree cost 3100
and
interface FastEthernet7/26
switchport
no ip address
speed 10
duplex full
The first one does not have switchport in the config and the second one has.
Please what is the difference?
Re: Switchport difference
I am not sure what switch model that you're using, basically "switchport" command configures that the particular port as a Layer 2 port.
You can read more about it from this link
http://www.cisco.com/warp/public/473/67.html#tbl-2
HTH,
Hieu
The difference is simple .Both the ports are capable of acting as a l2 as well as l3 port.
The first one is a L3 port .
The second one is converted L2 port from a L3 port.
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a008007e6a5.html#wp1041189
Hope this helps
regards
vanesh k
comment --> the first one is a L3 port.
if he got the output from a router then it's a L3 port but if he got the output from a switch then it's a L2 port
Thank you very much.
Does this mean if I omit the swithcport command, I can give the interface an ip addresses?
if it's a switch and you command "no switchport" you could put in an ip address and when you do sh run you would see on the int the "no switchport" statement
hi,
means that by default,all ports are L3 ports?
pls explain
regards,
nilay
No all the ports will be L2 on the switches except 6500 series.it would be better if u let us know the platfrom which u r using.
Mahmood
exactly my point. that's why i asked if what equipment is the port he's referring to.
trick question? :)
trick question?
what equipment is fx/x? what equipment is f7/26?
167
