switchport port-security aging static command
mahesh18
Level 6
Level 6
hi,
Can someone please explain we the above command with example.
many thanks
mahesh
mahesh18 wrote:
Hi Reza,
thanks for reply i read from cisco website following note but i did not understand what this mean
You can use port security aging to set the aging time for all secure addresses on a port.
Use this feature to remove and add PCs on a secure port without manually deleting the existing secure MAC addresses while still limiting the number of secure addresses on a port.
if you can explain me this please
mahesh
Mahesh
If you have a port security setting of 5 secure addresses allowed then when the switch has learnt these 5 addresses no more addresses will be allowed. If there is no aging time for the entries then the entry simply remains there as long as the switch is up. If you now want to remove one of the PC's and replace it with another you have a problem because the pot has already learned 5 addresses so it will not allow another.
This is where you use the aging timer. If for example you set the port-security aging timer to 1 then you would only have to wait one minute before the mac-address for the PC you disconnected is removed and now the switch only has 4 addresses learnt on that port. So you can now add your new PC and it will be allowed on that port and becomes the 5th address learned.
Jon
6 Replies 6
Reza Sharifi
Hi Reza,
mahesh
mahesh18 wrote:
Hi Reza,
mahesh
Mahesh
Jon
Hi Jon,
Many thanks for wonderful explanation.
best regards
mahesh
hanzawtunn
"Switchport port-security aging static" command enables aging of statically configured secured MAC address i.e., the addresses that you configured using “switchport port-security mac-address xxxx.xxxx.xxxx” command.
Issuing “switchport port-security aging static” and “switchport port-security aging time x” remove the statically configured address from the address-table and running configure.
When you check with “show run interface x” command, you will see that “switchport port-security mac-address xxxx.xxxx.xxxx” is missing from running configuration automatically after the aging time that you configured.
By checking with MACOF from Kali Linux and a switch, clear my confusion for this.
Sir Please Elaborate these things in simple words .
For What Purpose we use SecureStatic Address Aging .??
