06-27-2010 05:22 AM - edited 03-06-2019 11:46 AM
I have a basic trunk
int gx/x
sw trunk encap dot1q
sw tr native vlan 111
sw mo tr
I applied the command
switchport trunk allowed vlan remove 1607
and the IOS removed all the vlans from the trunk.Is it normal ?
Regs
Kas
Solved! Go to Solution.
06-27-2010 06:14 AM
No, its not normal and I'm not sure what you are doing wrong. You need to post more information.
I just tested here and it works as advertised on a 3560 switch:
Port Vlans allowed on trunk
Fa0/19 1-4094
Port Vlans allowed and active in management domain
Fa0/19 1,13,112,200,222
Port Vlans in spanning tree forwarding state and not pruned
Rack1SW4(config)#int f0/19
Rack1SW4(config-if)#sw tru allowed vlan remove 13
Rack1SW4(config-if)#end
Rack1SW4#sh run int f0/19
Building configuration...
Current configuration : 113 bytes
interface FastEthernet0/19
switchport trunk allowed vlan 1-12,14-4094
switchport mode dynamic desirable
Fa0/19 1-12,14-4094
Fa0/19 1,112,200,222
Edison
06-27-2010 06:14 AM
Fa0/19 1-4094
Fa0/19 1-12,14-4094
Edison
06-27-2010 08:36 AM
Hi edison,
Thanks for your reply.
I have attached truncated configuration of the switch taken on the 23rd June. Kindly note the configuration of G1/0/1. Today under this interface I had only applied the switchport trunk allowed vlan remove 1607.
What happened next was all vlans of that port vanished and whatever L3 device we had over that port communication went down as VLANS were not accessible.
I am not sure what went wrong ..Later i found that it was allowing the vlan 1607 and i had to revert back the original plain trunk configuration.
06-27-2010 03:09 PM
I don't see any manual pruning on the file that was attached:
interface GigabitEthernet1/0/1
description trunk to ----Gi0/1
switchport trunk native vlan 970
switchport mode trunk
speed 1000
duplex full
srr-queue bandwidth share 1 50 50 50
srr-queue bandwidth shape 3 0 0 0
priority-queue out
mls qos trust dscp
Perhaps the command was typed incorrectly. As I said, the command as indicated should work as advertised. An incorrect syntax can cause adverse effects.
Edison
