Webcast-Catalyst9k
switchport trunk native vlan
To Alls,
I wonder if we have to add the additional configurartion for the following situation. when we have a spare router, and I can but no luck to us.
LAN side.
interface x/x
switchport
switchport mode trunk
switchport trunk native vlan 10
- snip-
WAN router.
interface x/x
  no shutdown
interface x/x.xxx
encapsulation dot1Q 10 native
In this case, Do we have add 'native' option right behind ' encapsulation dot1Q ' as above?
otherwise, the connection from vlan 10 is not reachable each other?
Everyone's tags (5)
1 REPLY
Your configuration is correct, when the frame is sent out of the trunk port from the switch the tag is removed as it is a native vlan thus on the rotuer your subinterface should have config.
and router can identify that the frames that arrived untagged on the interface belongs to vlan 10.
Hitesh Vinzoda
Pls rate useful posts.
1109
