Sync configuration HSRP
hassamri
I have HSRP between 2 routers cisco and i would like to add a link of sync in order the configuration will be synchronise the moment we are doing a modifications on active router.
Someone can help me ?
5 Replies 5
Tricky, since you cannot simply copy the entire configuration to the other device, you would need to exclude at the very least the interface IP addresses.
Have a llok at the thread below:
https://supportforums.cisco.com/t5/eem-scripting/script-tcl-with-eem-for-sync-setting-in-routers-hsrp/td-p/2099595
I know there are some commercial tools out there such as KIWI Cattools...
http://www.solarwinds.com/kiwi-cattools
Please correct me if I understanding wrong the question, but basically the link (point to point) can be used with a /30 to interconnect 2 routers and it will keep sync the HSRP, for example:
In this case OSPF will be used to interconnect both routers and to sync the HSRP process.
ROUTER 1
interface g0/0
description TO-ROUTER2
ip address 10.0.0.1 255.255.255.252
interface g0/1
description LAN
ip address 192.168.12.2 255.255.255.0
standby 12 ip 192.168.12.1
standby 12 preempt
standby 12 priority 105
router ospf 100
net 192.168.12.0 0.0.0.255 area 0
net 10.0.0.0 0.0.0.3 area 0
ROUTER 2
interface g0/0
description TO-ROUTER1
ip address 10.0.0.2 255.255.255.252
interface g0/1
description LAN
ip address 192.168.12.3 255.255.255.0
standby 12 preempt
standby 12 priority 100
router ospf 100
You can modify this configuration to be adjusted to your network.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I would like to know just the configuration that i will need in order to automate the synchro of configuration betweek the Active/Standby cisco router
Example of firewall (Palo Alto, Checkpoint, Pfsense) : in the cluster you have absolutly the link of synchro that permit to synchronise configuration when someone make a modification on active firewall.
like that i wabt to do but and i'm blocked.
The heartbeat Link usually are seen on firewalls or some devices supporting multichassis for replication so the standby will create a mirror of the active device. What you like to approach?
