Community Member
synchronous
Hi all
can anybody tell the command is #logging synchronous for what.
thanks in advance.
1 REPLY
Re: synchronous
Please check:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/log.html#wp1083777
In more simple words, it synchronize the logging and debug output in order not to be hazardous when you are doing configuration. After the unsolicited messages are displayed, the console / VTY again displays the user prompt.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
158
