Community Member
SYS-4-P2_WARN:
Hi NetPro,
anyone encountered this before ?
2007 Sep 10 13:58:11 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 13:58:26 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 13:58:42 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 13:58:57 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 13:59:12 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 13:59:26 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 13:59:41 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 13:59:57 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:00:12 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:00:28 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:00:43 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:00:58 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:01:13 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:01:29 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:01:44 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:01:59 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:02:13 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:02:29 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:02:44 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
2007 Sep 10 14:02:59 Singapore +08:00 %SYS-4-P2_WARN: 1/Filtering MAC address 00-00-00-00-00-00 on port 1/1 from host table
your reply will be highly appreciated,
thanks
regards,
jackal
1 REPLY
Re: SYS-4-P2_WARN:
Hi Jackal,
The message the switch is reporting indicates, there is a packet with source MAC of all zero's which is an invalid packet. The format of the error was a little different in older CAT OS and the following page should help
http://www.cisco.com/warp/public/473/176.html#subtopic1l
The syslog message indicates that the switch refuses to learn the invalid address. However, the switch forwards traffic that is sourced from an all-zeros MAC address.
You might want to use a sniffer and identify where these packets are coming from.
Ankur
*Pls rate all helpfull post
511
