Syslog all commands
jkjackson
Is there a way in a 3560, 3750 switch and 3845, and 2811 router to tell it to send all config commands someone is typing on the router to a syslog server? Is this only available in TACACS+?
21 Replies 21
Edison Ortiz
You can do accounting and send the output to a RADIUS server as well
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsec_c/part05/schacct.htm
Joseph
Edison is right that the traditional solution for this was AAA accounting. Cisco has introduced a new feature which gives you the ability to track config changes to syslog rather than using aaa accounting. This link provides information about this new capability:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080454f73.html
I have not yet tested it but it sounds exactly like what you want.
Rick
Rick
Rick,
Somehow that feature escaped and I've used it many times in different implementations. That's definitely the solution the OP is after. I'm rating your post accordingly.
Edison
I am glad that you are familiar with this. It sounds very good but I have not yet had occasion to use it.
Thanks for the rating.
Rick
Rick
I am trying to configure this, however it does not seem to be sending the messages to the syslog server. Can you post me the relevant part of a working config? Thanks,
Can you post your config and we go from there ?
Did you also configure a line like:
logging [syslog server IP]
archive
log config
logging enable
logging size 200
notify syslog contenttype plaintext
hidekeys
no logging trap
logging (server IP)
enable logging trap
That worked, Great! But are there any way to log any command sent to the IOS and not just config changes?
Sorry, that's when you need AAA.
If you have a RADIUS server, you can configure accounting by pointing to that server. No need to purchase a TACACS+ server.
But where does it store the messages? I do have AAA configured via MS IAS, works great. I looked over the document you linked in the first reply and it didn't seem say where it logged the messages.
Let's see what you have configured thus far regarding AAA.
Please include the radius information as well.
Are you authenticating and receiving authorization via RADIUS ?
Yes, and offcourse it loggs a Windows Event log each time you log in. Is this the same way it will log the accounting events?
here is my AAA config
aaa new-model
aaa group server radius srv006
server xxx.xxx.xxx.xxx auth-port 1645 acct-port 1646
aaa authentication login default group (groupname) local
aaa authentication login console line
aaa authorization exec default group (groupname) if-authenticated
aaa session-id common
radius-server host xxx.xxx.xxx.xxx auth-port 1645 acct-port 1646
radius-server deadtime 1
radius-server key (rad key)
radius-server vsa send authentication
