11-28-2007 06:57 AM - edited 03-05-2019 07:40 PM
Hi!
I would like to send all events to begin with. But the Eventsmanager doesnt get any syslog activity. Is there other steps i need to do on the switch other then
->Logging myhostname?
If i want to monitor almost every event is default settiing good for this or can i use trap setting in a good way?
Kr
Mattias
12-05-2007 09:05 AM
You need to give the command "logging trap 6". 6 stands for Informational messages. Interface up or down transitions and system restart messages, displayed at the notifications level. Reload requests and low-process stack messages, displayed at the informational level. This message is only for information; switch functionality is not affected. Level 7 is debugging. But if this is enabled, then you will receive lot of messages and it can also affect the performace of the switch, so it is recommened to stick to level 6.
12-06-2007 04:52 AM
Thanks for your reply!
I have still problem with reporting to the syslog server. Syslogserver does not get any data from the switch.
Can i also secure the switch with access-list so that it's only visible from a specific iprange or ipadress? If yes how would that config look like?
I have attached config in a file!
