Syslog Server Required
munawar.zeeshan
I require a Syslog server for logging of Routers, Switches and PIX firewall ?
ANy help?
7 Replies 7
francisco_1
Level 7
Level 7
we use php-syslog-ng. it is a frontend for viewing syslog-ng messages logged to MySQL in realtime. It features customized searches based on device, priority, date, time, and message. very good.
http://www.debianadmin.com/syslog-ng-web-interface-front-end-or-gui-tools.html
ohassairi
Level 5
Level 5
use kiwisyslog simple and free
syslog-ng is very granular and you can specify
separate locations for each devices.
Furthermore, you can dump this into mySQL for
mining and analysis later.
i don't think Kiwi can do that and even if it
does, it requires MS SQL server for that which
is not free.
Can i get the direct link for, PIX Firewall Manager (PFM) and/or PIX Firewall Syslog Server (PFSS).
I have tried to locate the direct link on the cisco website but cant find either. if you can find it i am happy to use my CCO to download it for you.
good luck.
Franco
like i said before syslog-ng will do what you want. we use it for our cisco devices, routers, switches and firewalls
scristian
With syslog-ng
In syslog-ng.conf you put something like this
destination ra1 { file("/logging/sw/ra1"); };
filter f_ra1 { host(ip_ra1); };
log { source(net); filter(f_ra1); destination(ra1); };
and on cisco switch you put smth like this
#snmp-server enable traps syslog
