TACACS+ Administration in Cisco ACS 4.1
with the following the switch is working perfectly with what ever i configured in Cisco ACS....
aaa new-model
aaa authentication login default group tacacs+ enable local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
tacacs-server host 10.203.1.92 key checkingtheswitch
could able to check the report,logged in users, login & logout time, failied authentication & pass authentications, but i couldn't see anything in "TACACS+ Administration" in Cisco ACS, can any one help me in this regard?
The above configuration was good enuf for me, that even if the Cisco ACS is down for any other reason, i could still able to login with the local database on the switch if i use "aaa authorization exec default group tacacs+ if-authenticated"
but still i feel something could be missing, so please suggest me any other commands needs to be added.
1 REPLY
Re: TACACS+ Administration in Cisco ACS 4.1
May be it is due to the bug bug CSCsg97429. http://www.cisco.com/en/US/products/sw/secursw/ps2086/prod_release_note09186a00807ab436.html#wp164275
The patch information resolves this issue.
Click this link if you are using ACS for Windows: http://www.cisco.com/pcgi-bin/tablebuild.pl/acs-win-3des?psrtdcat20e2 and download:
?ACS-4.1.1.23-CSTacacs-SW-CSCsg97429.zip
?ACS-4.1.1.23-CSTacacs-SW-CSCsg97429-Readme.txt
Click this link if you are using ACS Solution Engine: http://www.cisco.com/pcgi-bin/tablebuild.pl/acs-soleng-3des?psrtdcat20e2 and download:
applAcs_4.1.1.23_ACS-4.1-CSTacacs-CSCsg97429.zip
176
