Tacacs authorization for Nexus5000 on ACS
I'm trying to configure authorization for a Nexus5020 and I cant find what I'm supposed to configure in ACS...
If I wanted to do Radius, it would be easy, simply provide as a Cisco-av pair " shell:roles=roleA ". The documentation does not say anything about configuring attribute for tacacs.
Re: Tacacs authorization for Nexus5000 on ACS
Here is a link for the config on the Nexus:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/sec_tacacsplus.html
If  this is what you are working with and you are using the GUI on the ACS, all you need to configure is:
allow the ip address of the Nexus to talk to the ACS
configure a pre-shared key on the ACS under TACACs
It is very similar to setting up radius.
Hope this is what your looking for.
Alex
Hello Dominic,
I am trying to set up my cisco switches to use Radius using my  ACS, however I am not finding any documentation do you still have the documentation for how to set up radius on ACS. If you have examples that would be helpful too, thanks!
Joanna
The NAS type must be defined as Cisco IOS/PIX6.0 RADIUS.
After that, you need to define the Av-pair in the group or user level. Take a look at the jpeg I have attached.
924
