11-10-2013 10:35 PM - edited 03-07-2019 04:31 PM
When are running bellow TACACS config on one of our CISCO 2911 switch.
We got a issue when ACS to AD connectivity failed on ACS unable to login with our local account
When tacacs usre down unable to login with our local account.
FYI, Please find the below config.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting commands 1 default
action-type start-stop
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa session-id common
tacacs-server host xx.xx.xx.xx
tacacs-server timeout 2
tacacs-server directed-request no-truncate
tacacs-server key 7 xxxxxxxxxxxxxxxx
line con 0
password 7 097C6E1A0A1247000F16
line aux 0
line 0/0/0 0/3/15
session-timeout 15
access-class 98 in
no exec
transport preferred telnet
transport input telnet
telnet transparent
line vty 0 4
access-class 23 in
privilege level 15
password 7 01232617481C561D2556
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
password 7 0236244818115F334854
transport input ssh
Kannan
11-10-2013 10:45 PM
Hi Kanana,
The configuration looks ok for me. However, can you clarify the following.
1) ACS down -->does it mean the service was down or the physical device itself was down?
TACACS wont' fallback to local until the reachability to the server goes down. I could see transport input is configured as SSH. Incase of TACACS fallback, the local credential should have a username and password because unlike TELNET which works only with password SSH doesn't work.
Thanks & Regards,
Karthick Murugan
CCIE#39285
11-10-2013 11:06 PM
Thanks Karthick,
The ACS is not physically down, We can see ACS to AD connectivity disconnected.
At this time of now we unable to login with our'a' account(I mean Tacacs account).
In the same LAN we are running Nexus devices(5K and 7K switches).
We can able to login with local account to all of the our Nexus devices only got issue with some devices(Cisco 2911 and CISCO ASR 1002)
Kannan
11-10-2013 11:09 PM
Hi Kanana,
Do you have the old back configuration? can you provide the entire configuration?
Karthick Murugan
CCIE#39285
11-10-2013 11:20 PM
Hi Karthick,
The below config part of other device CISCO 1002, we have a issue this device as well.
Note : For security reason removed some part of interface config.
version 15.1
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname xxxxxx
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa group server tacacs+ ACS
server xxxxxxxx
server xxxxxxxx
ip vrf forwarding Mgmt-intf
ip tacacs source-interface GigabitEthernet0
aaa authentication login default group ACS local
aaa authentication login console group ACS local
aaa authorization console
aaa authorization exec default group ACS local
aaa authorization exec console if-authenticated
aaa authorization commands 1 default group ACS local
aaa authorization commands 15 default group ACS local
ip source-route
no ip domain lookup
ip domain name li.apac
username xxxxxxx privilege 15 password 7 03005E19160B245E5E
username xxxxxxx privilege 15 password 7 1159415D4214095E572F7E
username xxxxxxx privilege 15 password 7 023E077B07041D791C
ip forward-protocol nd
no ip http server
no ip http secure-server
logging host xxxxxxx vrf Mgmt-intf
access-list 12 permit xxxxxx
cdp run
tacacs-server host xxxxxxkey 7 xxxxxx
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 03347B181518715E4A13
transport input ssh
line vty 5 15
transport input ssh
end
Kanna
11-10-2013 11:21 PM
Hi karthick,
When we remove the device list from ACS server, It's working fine with local account.
Kannan
11-10-2013 11:44 PM
Can you add login under the vty lines and check.
11-10-2013 11:59 PM
Hi Kannan,
I tried to recreate the scenario in my lab device with exact same configuration and it worked fine without any issues.
So, I still believe the switch finds the TACACS server reachable.
Do you have option to console into the switch and check the output of "show tcp brief" and ping to the TACACS server.
Karthick Murugan
11-11-2013 12:23 AM
Hi Karthick,
We have only remote login access,Still, The ACS - AD is disconnected.
We can able to login only Nexus switches with our Local account other devices like I mentioned ASR, 2911, 3750 switches not abloe to login with local account.
If problem means it could be happend with all the switches but some devices only having issue
