03-22-2008 09:52 AM - edited 03-05-2019 09:54 PM
Does any of you know if any one of the free TACACS+ servers support Cisco command auditing, as well as the user store in an LDAP database?
Also can someone send me a list of the free TACACS+ servers available? I remember Cisco having a free one but if I remember correctly it is not fully functional.
Solved! Go to Solution.
03-23-2008 08:55 AM
Hi, michael
There is a free version of tacacs+ for linux on cisco ftp site:
ftp://ftp-eng.cisco.com/pub/tacacs/
username:anonymous
password:your email address
It surely support command audit (or it won't be called AAA), but not sure about the integration with LDAP. You will be required a liitle bit linux's skill to install this program anyway.
Another Cisco product is called Secure ACS. Even the try version cost a bit (I forgot how much). Besides, the order procedure is not very easy(at least to me)
See if this is what you want, if it's not, goto the following page:
and repeat your question there.
SSLIN
03-22-2008 11:18 AM
you mean like this:
Sat Mar 22 15:15:39 2008 192.168.10.3 cciesec tty66 10.250.97.5 start task_id=390 timezone=UTC service=shell start_time=1206209779
Sat Mar 22 15:15:41 2008 192.168.10.3 cciesec tty66 10.250.97.5 stop task_id=390 timezone=UTC service=shell start_time=1206209780 priv-lvl=0 cmd=enable
Sat Mar 22 15:15:43 2008 192.168.10.3 cciesec tty66 10.250.97.5 stop task_id=391 timezone=UTC service=shell start_time=1206209783 priv-lvl=15 cmd=configure terminal
Sat Mar 22 15:15:45 2008 192.168.10.3 cciesec tty66 10.250.97.5 stop task_id=392 timezone=UTC service=shell start_time=1206209784 priv-lvl=15 cmd=interface Loopback 0
Sat Mar 22 15:15:45 2008 192.168.10.3 cciesec tty66 10.250.97.5 stop task_id=393 timezone=UTC service=shell start_time=1206209785 priv-lvl=15 cmd=shutdown
Sat Mar 22 15:15:46 2008 192.168.10.3 cciesec tty66 10.250.97.5 stop task_id=394 timezone=UTC service=shell start_time=1206209786 priv-lvl=15 cmd=no shutdown
Sat Mar 22 15:15:48 2008 192.168.10.3 cciesec tty66 10.250.97.5 stop task_id=395 timezone=UTC service=shell start_time=1206209788 priv-lvl=0 cmd=exit
Sat Mar 22 15:15:49 2008 192.168.10.3 cciesec tty66 10.250.97.5 stop task_id=390 timezone=UTC service=shell start_time=1206209779 disc-cause=1 disc-cause-ext=9 pre-session-time=3 elapsed_time=9
This is a very powerful link:
03-22-2008 12:48 PM
What???
You lost me, dude.
03-23-2008 08:55 AM
Hi, michael
username:anonymous
SSLIN
03-23-2008 09:49 AM
SSLIN:
Thank you very much for your time.
MW
03-23-2008 02:07 PM
"Does any of you know if any one of the free TACACS+ servers
in an LDAP database?"
you can find it here:
http://www.shrubbery.net/tools.html
"There is a free version of tacacs+ for linux on cisco ftp site:
username:anonymous
password:your email address"
This version is very old. The newer version is at:
There are many new features in this version. It is an
"enhanced" version of Cisco Freeware tacacs
"but not sure about the integration with LDAP"
Yes, it will support LDAP and One-Time-Password (OTP);
however, you have to understand C programming to make
it work. I got it to work with LDAP, OTP and SecurID
by hacking the source code. It is not that difficult
once you read and understand the source code. In
term of installing it on Linux, it is as easy as 1-2-3.
"./configure, make and make install and that's it.
CCIE Security
03-23-2008 04:43 PM
Thanks, Mr CCIE security. :-)
