Community Member
tagged and untagged port
how to configure tagged and untagged port in cisco 4500switch?
tn.linkedin.com/in/mbarkimohamed/ GSM. (00 216) 93 124 999/ 22 741 725
Hello, Not sure what you mean
Not sure what you mean but remember that tags only flow over Trunk links,
Now if you want a specific subnet/vlan to be untagged then just make sure it's the native VLAN.
Makes sense?
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Community Member
hello  ok thank you julio,
hello
ok thank you julio,
but can you explain with an example of configurations
regards.
Hi,I am not going to you use
I am not going to you use your diagram just explaining here:
Below explanation in layman term:
1)
Access Port---Means untagged port.
Int f0/1
Switchport mode access
Switchport access vlan 10 >> Which means the port is part of vlan 10 and its in untagged state.
Trunk Port--Means Tagged Port:
Int G0/1
Switchport mode trunk
Switchport trunk allowed vlan 10 >>> Which means that if the trunk is up and working fine the packet going out of this interface would have tag on it with vlan 10. Trunk port - frames will be sent with VLAN tag. If only one VLAN allowed, then only frames with allowed vlan tag will be sent
Switchport trunk allowed native vlan 20  >>> Which means that the packet though it is passing through the trunk port but still it would not be tagged.
2)
Another way of explaining this would be:
A trunk allows pretagged packets to passthrough without changing the tag while an access port takes the packets it receives and retags them.
Ex.  To setup a trunk to allows all vlans(pretagged) traffic to flow to and from it
int fa0/0
switchport mode trunk <------ explicitly making this port a trunk rather than allowing it to "negotiate" its role (only command needed)
Ex.  To setup an access port and telling to tag the traffic as vlan 10
int f0/1
switchport mode access <----- explicitly making this an access port rather than allowing it to "negotiate" its role
switchport access vlan 10  <--------- tell this interface to tag any traffic entering the port as vlan 10
446
