Webcast-Catalyst9k
tar /x tftp rror opening flash/xxx.bin (No such file or directory
Switch#tar /x tftp://ip address/c3500xl-c3h2s-tar.120-5.WC17.tar flash
Loading c3500xl-c3h2s-tar.120-5.WC17.tar from 152.10.168.3 (via VLAN1): !
extracting c3500xl-c3h2s-mz.120-5.WC17.bin (1811552 bytes)
%Error opening flash/c3500xl-c3h2s-mz.120-5.WC17.bin (No such file or directory
I have tried on two 3512-XL-EN,same problem  so I've no idea how to upgrade ios in a normal way,at this point my solution is copy all the files one by one using copy tftp flash  (fortunately there are less than 20 files)
tftp server log:Solar WInds tftp server 10.4.0.10
2010-05-13 04:05:34,250 [3] INFO  TFTPServer.Service.PacketParser.RequestPacket - Received request packet, file name: c3500xl-c3h2s-tar.120-5.WC17.tar, transfer mode: binary, block size: , tsize: , timeout:
2010-05-13 04:05:34,250 [6] INFO  TFTPServer.Service.ConnectionPool - Beginning processing GET request from 152.10.168.11:57520, file name: c3500xl-c3h2s-tar.120-5.WC17.tar, transfer mode: binary,
2010-05-13 04:05:34,281 [3] INFO  TFTPServer.Service.PacketParser.ErrorPacket - <log4net.Error>Exception during StringFormat: Input string was not in a correct format. <format>Received error packet, code: {0}, message: {1w}.</format><args>{Disk full or allocation exceeded, Buffer overflow}</args></log4net.Error>
2010-05-13 04:05:34,359 [5] INFO  TFTPServer.Service.PacketParser.RequestPacket - Received request packet, file name: c3500xl-c3h2s-tar.120-5.WC17.tar, transfer mode: binary, block size: , tsize: , timeout:
2010-05-13 04:05:34,390 [3] INFO  TFTPServer.Service.TransmissionGet - Received error packet, tearing down connection. Error code: Disk full or allocation exceeded, message: Buffer overflow
2010-05-13 04:05:34,390 [6] INFO  TFTPServer.Service.ConnectionPool - Beginning processing GET request from 152.10.168.11:55369, file name: c3500xl-c3h2s-tar.120-5.WC17.tar, transfer mode: binary,
2010-05-13 04:05:34,406 [3] INFO  TFTPServer.Service.PacketParser.ErrorPacket - <log4net.Error>Exception during StringFormat: Input string was not in a correct format. <format>Received error packet, code: {0}, message: {1w}.</format><args>{Unknown, Session terminated}</args></log4net.Error>
2010-05-13 04:05:34,406 [3] INFO  TFTPServer.Service.TransmissionGet - Received error packet, tearing down connection. Error code: Unknown, message: Session terminated
Using WIreShark,I see 2 error packages every time I do this
first one is buffer overflow code 3
and the second one is unknown error code 0 and session terminated
I think something might cause this problem is flash directory
Switch#dir
Directory of flash:/
  2  -rwx     1811584   Jan 01 1970 00:09:34  c3500xl-c3h2s-mz.120-5.WC17.bin
  3  -rwx       94680   Jul 18 2000 01:47:40  c3500XL-diag-mz-120.5.2-XU
  4  drwx          64   Mar 01 1993 00:32:11  html
  6  -rwx         437   Jan 01 1970 00:03:38  env_vars
  8  -rwx         809   Mar 01 1993 00:10:23  config.text
3612672 bytes total (1703424 bytes free)
Switch#dir flash
Directory of flash:/flash
No such file
weird? in the documents it shouldn't be no such file.... dir works as dir flash and dir flash doesn't work?
I also tried Tftpd32,still same problem
any cure? Thanks
Everyone's tags (4)
Re: tar /x tftp rror opening flash/xxx.bin (No such file or dir
hi
I see you tried with tar /x tftp://ip address/c3500xl-c3h2s-tar.120-5.WC17.tar flash
can you try tar /x tftp://ip address/c3500xl-c3h2s-tar.120-5.WC17.tar flash:
regds
2010-05-13 04:05:34,281 [3] INFO  TFTPServer.Service.PacketParser.ErrorPacket - Exception during StringFormat: Input string was not in a correct format. Received error packet, code: {0}, message: {1w}.{Disk full or allocation exceeded, Buffer overflow}
2010-05-13 04:05:34,406 [3] INFO  TFTPServer.Service.PacketParser.ErrorPacket - Exception during StringFormat: Input string was not in a correct format. Received error packet, code: {0}, message: {1w}.{Unknown, Session terminated}
Switch#dir
Switch#dir flash
No such file
any cure? Thanks
As suggested by premkumar try with the following command switch# tar /x tftp://server_ip_address//path/filename.tar flash: and make sure to have insert a single space after tar, after /x, and before flash:
Hope to help !!
Ganesh.H
Remember to rate the helpful post
Turn off Windows Firewall and
Turn off Windows Firewall and try!
3436
