Tcam resource exhausted on Nexus 7010 M1 card
Anybody seen the issue below yet? I am on NX-OS 5.2.1. The Mod is M1 card. The FEX port (Nexus 2248) end up in err-disabled after TCAM exhauseted. I have to remove "QoS" policy on that port and bounce the port. Than it will come back up again.
2011 Nov  5 01:20:03 BNZ-AKDCM1-L01-DC-02 %ACLQOS-SLOT9-2-ACLQOS_OOTR: Tcam resource exhausted: tcam 0, bank 1
2011 Nov  5 01:20:03 BNZ-AKDCM1-L01-DC-02 %ACLQOS-SLOT10-2-ACLQOS_OOTR: Tcam resource exhausted: tcam 0, bank 1
2011 Nov  5 01:20:03 BNZ-AKDCM1-L01-DC-02 %ETHPORT-5-IF_SEQ_ERROR: Error ("Sufficient free entries are not available in TCAM bank") communicating with MTS_SAP_IPQOS_MGR for opcode MTS_OPC_ETHPM_PORT_BRINGUP (RID_PORT: Ethernet103/1/13)
2011 Nov  5 01:20:03 BNZ-AKDCM1-L01-DC-02 %ETHPORT-2-IF_DOWN_ERROR_DISABLED: Interface Ethernet103/1/13 is down (Error disabled. Reason:Sufficient free entries are not available in TCAM bank)
        ACL Hardware Resource Utilization (Module 9)
                          Used    Free    Percent
                                          Utilization
Tcam 0, Bank 0            2       16382   0.01
Tcam 0, Bank 1            16173   211     98.71<------Almost maxed out!
Tcam 1, Bank 0            7       16377   0.04
Tcam 1, Bank 1            155     16229   0.94
LOU                       3       101     2.88
Both LOU Operands         2
Single LOU Operands       1
LOU L4 src port:          0
LOU L4 dst port:          1
LOU L3 packet len:        0
LOU IP tos:               0
LOU IP dscp:              0
LOU ip precedence:        0
LOU ip TTL:               0
TCP Flags                 0       16      0.00
Protocol CAM              3       4       42.85
Mac Etype/Proto CAM       7       7       50.00
Non L4op labels, Tcam 0   35      6108    0.56
Non L4op labels, Tcam 1   1       6142    0.01
L4 op labels, Tcam 0      0       2047    0.00
L4 op labels, Tcam 1      1       2046    0.04
Ingress Dest info table   1       511     0.19
Egress Dest info table    0       512     0.00
BNZ-AKDCM1-L01-DC-02# show system internal access-list feature bank map interface ingress module 9
_________________________________________________________________________
Feature                Rslt Type      T0B0      T0B1      T1B0      T1B1
PACL                       Acl         X
RACL                       Acl                             X
DHCP                       Acl                             X
QoS                        Qos                   X
PBR                        Acl                             X
Netflow                    Acl         X         X                   X
Netflow Sampler            Acc                                       X
SPM WCCP                   Acl         X                   X         X
BFD                        Acl                             X
SPM OTV                    Acl         X
FEX                        Acl         X
SPM CBTS                   Acl         X         X
SPM LISP INST              Acl         X         X
BNZ-AKDCM1-L01-DC-02# show system internal access-list feature bank map interface egress module 9
QoS                        Qos                                       X
RACL                       Acl                             X
Tunnel Decap               Acl         X
Netflow                    Acl                             X         X
Rbacl                      Acl         X         X
CTS implicit Tunnel        Acl                             X
SPM WCCP                   Acl         X
SPM OTV                    Acl         X
SPM LISP                   Acl         X
SPM ERSPAN (termination)   Acl         X         X         X
1 ACCEPTED SOLUTION
Hi Ben,
are you using wccp? I have seen similar with it as it makes TCAM load be calculated with exponential values.
Let's say, we have the following:
X = amount of access-list entries
Y = the amount of bits in the WCCP DST IP MASK advertised (for example:
0.0.23.65 [00000000.00000000.00010111.01000001] = 6 bits).
Then the amount of TCAM entries will be:
X * 2 tcp ports * 2^Y * 2 = normal amount of TCAM entries.
For example if we have:
X = 60 access-list lines.
Y = 6 bits
This then gives a total of: 60 * 2 * 2^6 * 2 = 15360.
Make sure to minimize the following entries:
* Amount of ACL entries.
* Reduce the MASK send by and configured on the WCCP appliance.
as seen in show ip wccp vrf default detail
                       M A S K
           Source     Destination    Sport  Dport
           0x00000000 0x00001741     0x0000 0x0000
                       M A S K
Nik
Hi Ben,
Y = 6 bits
                       M A S K
                       M A S K
Nik
No, I am not running WCCP.  Here is the solution by using the "hardware access-list resouce pooling" command.
##Enable TCAM resoruce sharing##
hardware access-list resource pooling module 9
hardware access-list resource pooling module 10
## Reload the module to take effect##
reload module 9
reload module 10
##Verify with this commands##
show system internal access-list globals module 9
sh hardware access-list resource utilization module 9
show system internal access-list globals module 10
sh hardware access-list resource utilization module 10
3013
