TCAM utilization WS-C3750G-24TS-1U
Hi Friends,
I am trying to analyze the capacity of one of my L3 switches for provisioning a new connectivity. When I check the TCAM util of the device I can see that the QOS aces and the PBR ace's are almost full. On this device however there are no QOS or PBR ace's. Can someone please suggest why do these entries show up in the table if there are no such ace's configured.
mumtat01eer01#sh platform tcam utilization
CAM Utilization for ASIC# 0                      Max            Used
                                             Masks/Values    Masks/values
Unicast mac addresses:                        528/4224         15/39
IPv4 IGMP groups + multicast routes:          152/1216          6/26
IPv4 unicast directly-connected routes:       528/4224         15/39
IPv4 unicast indirectly-connected routes:     272/2176        173/1275
IPv4 policy based routing aces:               512/512           2/2
IPv4 qos aces:                                768/768         388/388
IPv4 security aces:                          1024/2048        122/314
Thanks in Advance
Umesh Shetty
Hi Umesh,
Hmm, you do not seem to be at the limits. Out of 512 masks and values for PBR ACEs, you are using only 2. And out of 768 masks and values for QoS ACEs, you seem to be using only 388 entries. You are not hitting the limits anytime soon.
But I would like to see your running-config to see where the QoS ACEs could come from.
Best regards,
Peter
Hi Peter,
Apologies for the delay in responding..here is he full config.
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname XXXXXX
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login async none
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
clock timezone IST 5 30
clock summer-time BST recurring
switch 1 provision ws-c3750g-24ts-1u
system mtu routing 1500
vtp mode transparent
authentication mac-move permit
ip subnet-zero
no ip source-route
ip routing
ip cef load-sharing algorithm universal 1365B601
no ip domain-lookup
ip domain-name in.db.com
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
ip ssh version 2
interface Loopback0
ip address 10.174.37.140 255.255.255.255
interface GigabitEthernet1/0/1
no switchport
ip address 10.174.40.70 255.255.255.240
ip access-group TRAFFIC_FRM_EUS_AND_IPC in
standby 1 ip 10.174.40.72
standby 1 timers 1 3
standby 1 preempt delay minimum 60 reload 60
interface GigabitEthernet1/0/2
shutdown
interface GigabitEthernet1/0/3
shutdown
interface GigabitEthernet1/0/4
shutdown
interface GigabitEthernet1/0/5
no switchport
bandwidth 102400
ip address 10.182.214.62 255.255.255.252
ip ospf network point-to-point
ip ospf cost 150
ip ospf hello-interval 1
ip ospf dead-interval 3
speed 100
duplex full
srr-queue bandwidth share 1 3 97 1
priority-queue out
udld port aggressive
mls qos trust dscp
no mdix auto
interface GigabitEthernet1/0/6
shutdown
interface GigabitEthernet1/0/7
shutdown
interface GigabitEthernet1/0/8
shutdown
interface GigabitEthernet1/0/9
shutdown
interface GigabitEthernet1/0/10
shutdown
interface GigabitEthernet1/0/11
shutdown
interface GigabitEthernet1/0/12
shutdown
interface GigabitEthernet1/0/13
shutdown
interface GigabitEthernet1/0/14
shutdown
interface GigabitEthernet1/0/15
shutdown
interface GigabitEthernet1/0/16
shutdown
interface GigabitEthernet1/0/17
shutdown
interface GigabitEthernet1/0/18
shutdown
interface GigabitEthernet1/0/19
shutdown
interface GigabitEthernet1/0/20
shutdown
interface GigabitEthernet1/0/21
shutdown
interface GigabitEthernet1/0/22
no switchport
ip address 10.174.40.98 255.255.255.252
ip access-group TRAFFIC_FROM_DBNET in
ip ospf cost 150
ip ospf hello-interval 3
ip ospf dead-interval 10
interface GigabitEthernet1/0/23
no switchport
ip address 10.174.40.102 255.255.255.252
ip ospf cost 250
interface GigabitEthernet1/0/24
no switchport
ip address 10.174.40.105 255.255.255.252
ip ospf cost 150
interface GigabitEthernet1/0/25
shutdown
interface GigabitEthernet1/0/26
shutdown
interface GigabitEthernet1/0/27
shutdown
interface GigabitEthernet1/0/28
shutdown
interface Vlan1
no ip address
shutdown
router ospf 110
router-id 10.174.37.140
log-adjacency-changes
redistribute static metric 100 metric-type 1 subnets
passive-interface default
no passive-interface GigabitEthernet1/0/5
no passive-interface GigabitEthernet1/0/22
no passive-interface GigabitEthernet1/0/23
no passive-interface GigabitEthernet1/0/24
network 10.174.37.140 0.0.0.0 area 0.0.0.5
network 10.174.40.64 0.0.0.15 area 0.0.0.5
network 10.174.40.96 0.0.0.3 area 0.0.0.5
network 10.174.40.100 0.0.0.3 area 0.0.0.5
network 10.174.40.104 0.0.0.3 area 0.0.0.5
network 10.182.214.60 0.0.0.3 area 0.0.0.5
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 10.174.32.0 255.255.255.0 10.174.40.67
ip route 10.174.36.0 255.255.255.0 10.174.40.67
no ip http server
no ip http secure-server
ip tacacs source-interface Loopback0
ip access-list extended TRAFFIC_FRM_EUS_AND_IPC
permit tcp any any established
permit ip host 10.174.40.68 any
permit ip host 10.174.40.69 any
permit udp host 10.174.40.71 host 224.0.0.2 eq 1985
permit udp host 10.174.40.70 host 224.0.0.2 eq 1985
permit tcp 10.174.36.0 0.0.0.255 host 10.239.24.156 eq 2967
permit tcp 10.174.36.0 0.0.0.255 host 10.171.194.181 eq 2967
permit tcp 10.174.32.0 0.0.0.255 host 10.239.24.156 eq 2967
permit tcp 10.174.32.0 0.0.0.255 host 10.171.194.181 eq 2967
permit udp 10.174.36.0 0.0.0.255 host 10.171.194.181 eq 38293
permit udp 10.174.36.0 0.0.0.255 host 10.239.24.156 eq 38293
permit udp 10.174.32.0 0.0.0.255 host 10.171.194.181 eq 38293
permit udp 10.174.32.0 0.0.0.255 host 10.239.24.156 eq 38293
permit udp 10.174.36.0 0.0.0.255 host 10.239.23.7 eq syslog
permit udp 10.174.32.0 0.0.0.255 host 10.239.23.7 eq syslog
permit udp 10.174.36.0 0.0.0.255 host 10.174.5.230 eq domain
permit udp 10.174.36.0 0.0.0.255 host 10.174.49.230 eq domain
permit udp 10.174.36.0 0.0.0.255 host 10.171.11.1 eq domain
permit udp 10.174.36.0 0.0.0.255 host 10.171.11.1 eq ntp
permit udp 10.174.36.0 0.0.0.255 host 10.171.196.1 eq ntp
permit udp 10.174.36.0 0.0.0.255 host 10.171.11.55 eq ntp
permit udp 10.174.32.0 0.0.0.255 host 10.174.5.230 eq domain
permit udp 10.174.32.0 0.0.0.255 host 10.174.49.230 eq domain
permit udp 10.174.32.0 0.0.0.255 host 10.171.11.1 eq domain
permit udp 10.174.32.0 0.0.0.255 host 10.171.11.1 eq ntp
permit udp 10.174.32.0 0.0.0.255 host 10.171.196.1 eq ntp
permit udp 10.174.32.0 0.0.0.255 host 10.171.11.55 eq ntp
permit tcp host 10.174.36.3 10.140.52.0 0.0.0.255 eq 5712
permit tcp host 10.174.36.3 10.140.51.0 0.0.0.255 eq 5712
permit tcp host 10.174.36.3 10.140.44.0 0.0.0.255 eq 5712
permit tcp host 10.174.36.3 10.152.49.0 0.0.0.255 eq 5712
permit tcp host 10.174.36.3 10.228.10.0 0.0.0.255 eq 5712
permit tcp host 10.174.36.3 10.229.10.0 0.0.0.255 eq 5712
permit udp host 10.174.36.18 host 10.174.39.216 eq 2000
permit udp host 10.174.36.19 host 10.174.39.216 eq 2000
permit udp host 10.174.36.17 host 10.171.15.219 eq 7071
permit udp host 10.174.36.17 host 10.171.15.218 eq 7071
permit udp host 10.174.36.17 host 10.174.5.83 eq 52311
permit udp host 10.174.36.17 host 10.174.47.172 eq 52311
permit udp host 10.174.36.17 host 10.152.41.58 eq 52311
permit icmp host 10.174.36.121 host 10.174.50.40 echo-reply
permit icmp host 10.174.36.121 host 10.174.50.60 echo-reply
permit icmp host 10.174.36.121 host 10.174.39.216 echo-reply
permit icmp host 10.174.36.122 host 10.174.50.40 echo-reply
permit icmp host 10.174.36.122 host 10.174.50.60 echo-reply
permit icmp host 10.174.36.122 host 10.174.39.216 echo-reply
permit icmp host 10.174.36.123 host 10.174.50.40 echo-reply
permit icmp host 10.174.36.123 host 10.174.50.60 echo-reply
permit icmp host 10.174.36.123 host 10.174.39.216 echo-reply
permit icmp host 10.174.36.124 host 10.174.50.40 echo-reply
permit icmp host 10.174.36.124 host 10.174.50.60 echo-reply
permit icmp host 10.174.36.124 host 10.174.39.216 echo-reply
permit icmp host 10.174.36.125 host 10.174.50.40 echo-reply
permit icmp host 10.174.36.125 host 10.174.50.60 echo-reply
permit icmp host 10.174.36.125 host 10.174.39.216 echo-reply
permit icmp host 10.174.36.126 host 10.174.50.40 echo-reply
permit icmp host 10.174.36.126 host 10.174.50.60 echo-reply
permit icmp host 10.174.36.126 host 10.174.39.216 echo-reply
permit udp 10.174.36.0 0.0.0.255 host 10.171.180.136 eq snmp
permit udp 10.174.36.0 0.0.0.255 host 10.171.182.136 eq snmp
permit udp 10.174.32.0 0.0.0.255 host 10.171.180.136 eq snmp
permit udp 10.174.32.0 0.0.0.255 host 10.171.182.136 eq snmp
permit udp 10.174.36.0 0.0.0.255 host 10.172.253.3 eq snmp
permit udp 10.174.36.0 0.0.0.255 host 10.171.215.3 eq snmp
permit udp 10.174.32.0 0.0.0.255 host 10.172.253.3 eq snmp
permit udp 10.174.32.0 0.0.0.255 host 10.171.215.3 eq snmp
permit udp 10.174.36.0 0.0.0.255 host 10.171.180.136 eq snmptrap
permit udp 10.174.36.0 0.0.0.255 host 10.171.182.136 eq snmptrap
permit udp 10.174.32.0 0.0.0.255 host 10.171.180.136 eq snmptrap
permit udp 10.174.32.0 0.0.0.255 host 10.171.182.136 eq snmptrap
permit udp 10.174.36.0 0.0.0.255 host 10.172.253.3 eq snmptrap
permit udp 10.174.36.0 0.0.0.255 host 10.171.215.3 eq snmptrap
permit udp 10.174.32.0 0.0.0.255 host 10.172.253.3 eq snmptrap
permit udp 10.174.32.0 0.0.0.255 host 10.171.215.3 eq snmptrap
permit udp 10.174.36.0 0.0.0.255 eq snmp host 10.171.180.136
permit udp 10.174.36.0 0.0.0.255 eq snmp host 10.171.182.136
permit udp 10.174.32.0 0.0.0.255 eq snmp host 10.171.180.136
permit udp 10.174.32.0 0.0.0.255 eq snmp host 10.171.182.136
permit tcp 10.174.36.0 0.0.0.255 host 10.171.195.13 eq 5600
permit tcp 10.174.36.0 0.0.0.255 host 10.171.195.13 eq 5601
permit tcp 10.174.32.0 0.0.0.255 host 10.171.195.13 eq 5600
permit tcp 10.174.32.0 0.0.0.255 host 10.171.195.13 eq 5601
permit tcp 10.174.36.0 0.0.0.255 host 10.239.10.15 eq 5600
permit tcp 10.174.36.0 0.0.0.255 host 10.239.10.15 eq 5601
permit tcp 10.174.32.0 0.0.0.255 host 10.239.10.15 eq 5600
permit tcp 10.174.32.0 0.0.0.255 host 10.239.10.15 eq 5601
permit tcp host 10.174.36.1 host 10.143.149.65 eq 22
permit tcp host 10.174.36.1 host 10.240.35.8 eq 22
permit tcp host 10.174.36.1 host 10.140.109.97 eq 22
permit icmp 10.174.32.0 0.0.0.255 host 10.174.40.72
permit icmp 10.174.36.0 0.0.0.255 host 10.174.40.72
permit tcp host 10.174.36.3 10.232.32.0 0.0.0.255 eq 5712
permit tcp host 10.174.36.3 10.140.57.0 0.0.0.255 eq 5712
permit udp 10.174.36.0 0.0.0.255 host 10.171.55.201 eq ntp
permit udp 10.174.36.0 0.0.0.255 host 10.234.55.201 eq ntp
permit udp 10.174.36.0 0.0.0.255 host 10.239.1.22 eq ntp
permit udp 10.174.36.0 0.0.0.255 host 10.171.199.201 eq ntp
permit tcp 10.174.36.0 0.0.0.255 host 10.152.41.58 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.152.41.58 eq 52312
permit tcp 10.174.36.0 0.0.0.255 host 10.152.41.58 eq www
permit tcp 10.174.36.0 0.0.0.255 host 10.153.50.76 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.153.50.76 eq 52312
permit tcp 10.174.36.0 0.0.0.255 host 10.153.50.76 eq www
permit tcp 10.174.36.0 0.0.0.255 host 10.152.242.29 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.152.242.29 eq 52312
permit tcp 10.174.36.0 0.0.0.255 host 10.152.242.29 eq www
permit tcp 10.174.36.0 0.0.0.255 host 10.152.189.140 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.152.189.140 eq 52312
permit tcp 10.174.36.0 0.0.0.255 host 10.152.189.140 eq www
permit tcp 10.174.36.0 0.0.0.255 host 10.174.5.51 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.174.5.51 eq 52312
permit tcp 10.174.36.0 0.0.0.255 host 10.174.5.51 eq www
permit udp 10.174.36.0 0.0.0.255 host 10.153.50.76 eq 52311
permit udp 10.174.36.0 0.0.0.255 host 10.153.50.76 eq 52312
permit udp 10.174.36.0 0.0.0.255 host 10.152.41.58 eq 52311
permit udp 10.174.36.0 0.0.0.255 host 10.152.41.58 eq 52312
permit udp 10.174.36.0 0.0.0.255 host 10.152.242.29 eq 52311
permit udp 10.174.36.0 0.0.0.255 host 10.152.242.29 eq 52312
permit udp 10.174.36.0 0.0.0.255 host 10.152.189.140 eq 52311
permit udp 10.174.36.0 0.0.0.255 host 10.152.189.140 eq 52312
permit udp 10.174.36.0 0.0.0.255 host 10.174.5.51 eq 52311
permit udp 10.174.36.0 0.0.0.255 host 10.174.5.51 eq 52312
permit udp 10.174.36.0 0.0.0.255 host 10.153.50.76 gt 1024
permit udp 10.174.36.0 0.0.0.255 host 10.152.41.58 gt 1024
permit udp 10.174.36.0 0.0.0.255 host 10.153.242.29 gt 1024
permit udp 10.174.36.0 0.0.0.255 host 10.152.189.140 gt 1024
permit udp 10.174.36.0 0.0.0.255 host 10.74.5.51 gt 1024
permit icmp 10.174.36.0 0.0.0.255 host 10.153.50.76 echo-reply
permit icmp 10.174.36.0 0.0.0.255 host 10.152.41.58 echo-reply
permit icmp 10.174.36.0 0.0.0.255 host 10.152.242.29 echo-reply
permit icmp 10.174.36.0 0.0.0.255 host 10.152.189.140 echo-reply
permit icmp 10.174.36.0 0.0.0.255 host 10.174.5.51 echo-reply
permit icmp 10.174.36.0 0.0.0.255 host 10.153.242.29 echo
permit tcp 10.174.36.0 0.0.0.255 host 10.174.5.138 eq 1500
permit tcp 10.174.36.0 0.0.0.255 host 10.174.5.138 eq 1502
permit tcp 10.174.36.0 0.0.0.255 host 10.174.47.222 eq 1500
permit tcp 10.174.36.0 0.0.0.255 host 10.174.47.222 eq 1502
permit tcp 10.174.36.0 0.0.0.255 host 10.174.49.149 eq 1500
permit tcp 10.174.36.0 0.0.0.255 host 10.174.49.149 eq 1502
permit tcp 10.174.36.0 0.0.0.255 host 10.174.12.68 eq 1500
permit tcp 10.174.36.0 0.0.0.255 host 10.174.12.68 eq 1502
permit tcp host 10.174.36.6 host 10.232.65.69 eq 5000
permit tcp host 10.174.36.6 host 10.235.16.9 eq 5000
permit tcp host 10.174.36.6 host 10.232.65.69 eq 443
permit tcp host 10.174.36.6 host 10.235.16.9 eq 443
permit udp host 10.174.36.6 host 10.232.65.69 gt 1024
permit udp host 10.174.36.6 host 10.235.16.9 gt 1024
permit udp host 10.174.36.6 host 10.232.65.69 eq 5000
permit udp host 10.174.36.6 host 10.235.16.9 eq 5000
permit udp host 10.174.36.6 host 10.232.65.69 eq 5001
permit udp host 10.174.36.6 host 10.235.16.9 eq 5001
permit udp host 10.174.36.6 host 10.128.120.21 eq snmp
permit udp host 10.174.36.6 host 10.128.120.21 eq snmptrap
permit udp host 10.174.36.6 host 10.128.120.22 eq snmp
permit udp host 10.174.36.6 host 10.128.120.22 eq snmptrap
permit udp host 10.174.36.19 host 10.174.39.216 gt 1024
permit udp host 10.174.36.18 host 10.174.39.216 gt 1024
permit tcp 10.174.36.0 0.0.0.255 host 10.171.100.18 eq www
permit tcp 10.174.36.0 0.0.0.255 host 10.171.100.18 eq 8080
permit tcp 10.174.36.0 0.0.0.255 host 10.239.36.18 eq www
permit tcp 10.174.36.0 0.0.0.255 host 10.239.36.18 eq 8080
permit tcp host 10.174.36.6 10.170.104.0 0.0.0.255 eq www
permit tcp host 10.174.36.6 10.170.104.0 0.0.0.255 eq 433
permit tcp host 10.174.36.6 10.170.104.0 0.0.0.255 eq 3381
permit tcp host 10.174.36.6 host 10.242.132.145 eq www
permit tcp host 10.174.36.6 host 10.242.132.145 eq 433
permit tcp host 10.174.36.6 host 10.242.132.145 eq 3381
permit tcp host 10.174.36.6 host 10.242.132.147 eq www
permit tcp host 10.174.36.6 host 10.242.132.147 eq 433
permit tcp host 10.174.36.6 host 10.242.132.147 eq 3381
permit tcp host 10.174.36.6 host 10.242.133.145 eq www
permit tcp host 10.174.36.6 host 10.242.133.145 eq 433
permit tcp host 10.174.36.6 host 10.242.133.145 eq 3381
permit tcp host 10.174.36.6 host 10.242.133.147 eq www
permit tcp host 10.174.36.6 host 10.242.133.147 eq 433
permit tcp host 10.174.36.6 host 10.242.133.147 eq 3381
  permit tcp host 10.174.25.100 host 10.174.36.20 eq www
permit tcp host 10.182.108.221 host 10.174.36.20 eq www
permit tcp host 10.182.108.223 host 10.174.36.20 eq www
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62070
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62070
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62070
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62072
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62072
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62072
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62074
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62074
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62074
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62076
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62076
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62076
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62077
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62077
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62077
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62078
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62078
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62078
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62079
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62079
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62079
permit tcp host 10.174.25.100 host 10.174.36.20 eq 62048
permit tcp host 10.182.108.221 host 10.174.36.20 eq 62048
permit tcp host 10.182.108.223 host 10.174.36.20 eq 62048
permit tcp host 10.174.25.100 host 10.174.36.18 eq 2001
permit tcp host 10.182.108.221 host 10.174.36.18 eq 2001
permit tcp host 10.182.108.223 host 10.174.36.18 eq 2001
permit tcp host 10.174.25.100 host 10.174.36.18 eq 2011
permit tcp host 10.182.108.221 host 10.174.36.18 eq 2011
permit tcp host 10.182.108.223 host 10.174.36.18 eq 2011
permit tcp host 10.174.25.100 host 10.174.36.19 eq 2001
permit tcp host 10.182.108.221 host 10.174.36.19 eq 2001
permit tcp host 10.182.108.223 host 10.174.36.19 eq 2001
permit tcp host 10.174.25.100 host 10.174.36.19 eq 2011
permit tcp host 10.182.108.221 host 10.174.36.19 eq 2011
permit tcp host 10.182.108.223 host 10.174.36.19 eq 2011
permit udp host 10.174.25.100 host 10.174.36.18 eq 2000
permit udp host 10.182.108.221 host 10.174.36.18 eq 2000
permit udp host 10.182.108.223 host 10.174.36.18 eq 2000
permit udp host 10.174.25.100 host 10.174.36.19 eq 2000
permit udp host 10.182.108.221 host 10.174.36.19 eq 2000
permit udp host 10.182.108.223 host 10.174.36.19 eq 2000
permit tcp 10.174.36.0 0.0.0.255 host 10.171.237.149 eq 5600
permit tcp 10.174.36.0 0.0.0.255 host 10.239.10.195 eq 5600
permit tcp 10.174.36.0 0.0.0.255 host 10.171.237.149 eq 5601
permit tcp 10.174.36.0 0.0.0.255 host 10.239.10.195 eq 5601
permit tcp host 10.171.237.149 10.174.36.0 0.0.0.255 eq 5600
permit tcp host 10.239.10.195 10.174.36.0 0.0.0.255 eq 5600
permit tcp host 10.171.237.149 10.174.36.0 0.0.0.255 eq 5601
permit tcp host 10.239.10.195 10.174.36.0 0.0.0.255 eq 5601
permit udp host 10.174.36.18 host 10.174.25.100 gt 1024
permit udp host 10.174.36.18 host 10.182.108.221 gt 1024
permit udp host 10.174.36.18 host 10.182.108.223 gt 1024
permit udp host 10.174.36.19 host 10.174.25.100 gt 1024
permit udp host 10.174.36.19 host 10.174.108.221 gt 1024
permit udp host 10.174.36.19 host 10.174.108.223 gt 1024
permit tcp host 10.174.36.21 eq 2011 host 10.174.25.100
permit tcp host 10.174.36.21 eq 2001 host 10.174.25.100
permit tcp host 10.174.36.21 eq 2011 host 10.174.39.216
permit tcp host 10.174.36.21 eq 2001 host 10.174.39.216
permit tcp host 10.174.36.21 eq 2011 host 10.182.108.221
permit tcp host 10.174.36.21 eq 2001 host 10.182.108.221
permit tcp host 10.174.36.21 eq 2011 host 10.182.108.223
permit tcp host 10.174.36.21 eq 2001 host 10.182.108.223
permit udp host 10.174.36.21 eq 2000 host 10.174.25.100
permit udp host 10.174.36.21 eq 2000 host 10.174.39.216
permit udp host 10.174.36.21 eq 2000 host 10.182.108.221
permit udp host 10.174.36.21 eq 2000 host 10.182.108.223
permit udp 10.174.36.0 0.0.0.255 host 10.239.40.81 eq ntp
permit udp 10.174.36.0 0.0.0.255 host 10.171.195.220 eq ntp
permit tcp host 10.174.36.17 host 10.234.55.138 eq www
permit tcp host 10.174.36.17 host 10.234.55.138 eq 8080
permit udp 10.174.32.0 0.0.0.255 host 10.174.250.75 eq domain
permit udp 10.174.32.0 0.0.0.255 host 10.242.160.75 eq domain
permit udp 10.174.36.0 0.0.0.255 host 10.174.250.75 eq domain
permit udp 10.174.36.0 0.0.0.255 host 10.242.160.75 eq domain
permit udp 10.174.36.0 0.0.0.255 host 10.234.100.113 eq snmptrap
permit udp 10.174.32.0 0.0.0.255 host 10.234.100.113 eq snmptrap
permit udp 10.174.36.0 0.0.0.255 host 10.234.200.113 eq snmptrap
permit udp 10.174.32.0 0.0.0.255 host 10.234.200.113 eq snmptrap
permit tcp 10.174.36.0 0.0.0.255 172.23.0.0 0.0.255.255
permit udp 10.174.36.0 0.0.0.255 172.23.0.0 0.0.255.255
permit tcp 10.174.32.0 0.0.0.255 172.23.0.0 0.0.255.255
permit udp 10.174.32.0 0.0.0.255 172.23.0.0 0.0.255.255
permit tcp 10.174.36.0 0.0.0.255 host 10.182.54.20 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.182.54.112 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.182.54.113 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.182.60.222 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.242.160.96 eq 52311
permit tcp 10.174.36.0 0.0.0.255 host 10.242.162.109 eq 52311
permit icmp 10.174.36.0 0.0.0.255 host 10.182.54.20
permit icmp 10.174.36.0 0.0.0.255 host 10.182.54.112
permit icmp 10.174.36.0 0.0.0.255 host 10.182.54.113
permit icmp 10.174.36.0 0.0.0.255 host 10.182.60.222
permit icmp 10.174.36.0 0.0.0.255 host 10.242.160.96
permit icmp 10.174.36.0 0.0.0.255 host 10.242.162.109
permit tcp host 10.174.36.1 host 10.235.35.29 eq www
permit tcp host 10.174.36.1 host 10.235.35.29 eq 443
permit tcp host 10.174.36.1 host 10.235.35.29 eq 1543
permit tcp host 10.174.36.1 host 10.240.67.21 eq www
permit tcp host 10.174.36.1 host 10.240.67.21 eq 443
permit tcp host 10.174.36.1 host 10.240.67.21 eq 1543
permit udp host 10.174.36.1 host 10.235.35.29 eq snmptrap
permit udp host 10.174.36.1 host 10.240.67.21 eq snmptrap
permit tcp 10.174.32.0 0.0.0.255 host 10.235.35.29 eq 443
permit tcp 10.174.32.0 0.0.0.255 host 10.240.67.21 eq 443
permit tcp 10.174.36.0 0.0.0.255 host 10.235.35.29 eq 443
permit tcp 10.174.36.0 0.0.0.255 host 10.240.67.21 eq 443
permit tcp host 10.174.36.1 host 10.235.35.29 gt 1024
permit tcp host 10.174.36.1 host 10.240.67.21 gt 1024
permit udp 10.174.36.0 0.0.0.255 host 10.171.118.93 eq syslog
permit udp 10.174.36.0 0.0.0.255 host 10.171.118.106 eq syslog
permit udp 10.174.36.0 0.0.0.255 host 10.239.40.102 eq syslog
permit udp 10.174.36.0 0.0.0.255 host 10.239.40.106 eq syslog
permit udp 10.174.36.0 0.0.0.255 10.182.215.0 0.0.0.15 eq 5030
permit udp 10.174.36.0 0.0.0.255 10.182.215.0 0.0.0.15 eq 5032
permit udp 10.174.36.0 0.0.0.255 eq 5030 10.182.215.0 0.0.0.15
permit udp 10.174.36.0 0.0.0.255 eq 5032 10.182.215.0 0.0.0.15
permit udp 10.174.36.0 0.0.0.255 eq syslog 10.182.215.0 0.0.0.15
permit udp 10.174.36.0 0.0.0.255 eq ntp 10.182.215.0 0.0.0.15
permit icmp 10.174.36.0 0.0.0.255 10.182.215.0 0.0.0.15 echo
permit icmp host 10.174.36.1 10.187.103.0 0.0.0.127
permit icmp host 10.174.36.1 10.187.103.128 0.0.0.63
permit udp 10.174.36.0 0.0.0.255 10.187.103.0 0.0.0.127 eq 5032
permit udp 10.174.36.0 0.0.0.255 10.187.103.128 0.0.0.63 eq 5032
permit udp 10.174.36.0 0.0.0.255 10.187.103.0 0.0.0.127 eq 5030
permit udp 10.174.36.0 0.0.0.255 10.187.103.128 0.0.0.63 eq 5030
permit udp 10.174.36.0 0.0.0.255 eq 5032 10.187.103.0 0.0.0.127
permit udp 10.174.36.0 0.0.0.255 eq 5032 10.187.103.128 0.0.0.63
permit udp 10.174.36.0 0.0.0.255 eq 5030 10.187.103.0 0.0.0.127
permit udp 10.174.36.0 0.0.0.255 eq 5030 10.187.103.128 0.0.0.63
permit udp 10.174.36.0 0.0.0.255 eq syslog 10.187.103.0 0.0.0.127
permit udp 10.174.36.0 0.0.0.255 eq syslog 10.187.103.128 0.0.0.63
permit udp 10.174.36.0 0.0.0.255 eq ntp 10.187.103.0 0.0.0.127
permit udp 10.174.36.0 0.0.0.255 eq ntp 10.187.103.128 0.0.0.63
permit udp host 10.174.36.18 eq 2000 10.182.216.0 0.0.0.255
permit udp host 10.174.36.18 eq 2000 10.182.217.0 0.0.0.255
permit udp host 10.174.36.18 eq 2000 10.182.222.0 0.0.0.255
permit udp host 10.174.36.18 eq 2000 10.182.223.0 0.0.0.255
permit udp host 10.174.36.19 eq 2000 10.182.216.0 0.0.0.255
permit udp host 10.174.36.19 eq 2000 10.182.217.0 0.0.0.255
permit udp host 10.174.36.19 eq 2000 10.182.222.0 0.0.0.255
permit udp host 10.174.36.19 eq 2000 10.182.223.0 0.0.0.255
permit udp host 10.174.36.21 eq 2000 10.182.216.0 0.0.0.255
permit udp host 10.174.36.21 eq 2000 10.182.217.0 0.0.0.255
permit udp host 10.174.36.21 eq 2000 10.182.222.0 0.0.0.255
permit udp host 10.174.36.21 eq 2000 10.182.223.0 0.0.0.255
deny   ip any any log
ip access-list extended TRAFFIC_FROM_DBNET
permit ospf host 10.174.40.97 host 224.0.0.5
permit ospf host 10.174.40.101 host 224.0.0.5
permit ospf host 10.174.40.106 host 224.0.0.5
permit ospf host 10.174.40.105 host 224.0.0.5
permit ospf host 10.174.40.109 host 224.0.0.5
permit ospf host 10.174.40.113 host 224.0.0.5
permit ospf host 10.174.40.97 host 10.174.40.98
permit ospf host 10.174.40.101 host 10.174.40.102
permit ospf host 10.174.40.106 host 10.174.40.105
permit ospf host 10.174.40.105 host 10.174.40.106
permit ospf host 10.174.40.109 host 10.174.40.110
permit ospf host 10.174.40.113 host 10.174.40.114
permit ip any host 10.174.37.140
permit ip any host 10.174.37.141
permit ip any host 10.174.40.68
permit ip any host 10.174.40.69
permit ip any host 10.174.40.71
permit ip any host 10.174.40.70
permit ip any host 10.174.40.110
permit ip any host 10.174.40.114
permit ip any host 10.174.40.106
permit ip any host 10.174.40.98
permit ip any host 10.174.40.102
permit ip any host 10.174.40.105
permit udp host 10.171.194.181 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.239.24.156 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.171.194.181 10.174.32.0 0.0.0.255 gt 1024
permit udp host 10.239.24.156 10.174.32.0 0.0.0.255 gt 1024
permit tcp host 10.154.129.228 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.154.129.228 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.154.129.228 10.174.36.0 0.0.0.255 eq 443
permit tcp host 10.154.129.228 10.174.36.0 0.0.0.255 eq 22
permit tcp host 10.154.129.229 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.154.129.229 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.154.129.229 10.174.36.0 0.0.0.255 eq 443
permit tcp host 10.154.129.229 10.174.36.0 0.0.0.255 eq 22
permit tcp host 10.154.137.228 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.154.137.228 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.154.137.228 10.174.36.0 0.0.0.255 eq 443
permit tcp host 10.154.137.228 10.174.36.0 0.0.0.255 eq 22
permit tcp host 10.154.129.228 10.174.32.0 0.0.0.255 eq 3389
permit tcp host 10.154.129.228 10.174.32.0 0.0.0.255 eq www
permit tcp host 10.154.129.228 10.174.32.0 0.0.0.255 eq 443
permit tcp host 10.154.129.228 10.174.32.0 0.0.0.255 eq 22
permit tcp host 10.154.129.229 10.174.32.0 0.0.0.255 eq 3389
permit tcp host 10.154.129.229 10.174.32.0 0.0.0.255 eq www
permit tcp host 10.154.129.229 10.174.32.0 0.0.0.255 eq 443
permit tcp host 10.154.129.229 10.174.32.0 0.0.0.255 eq 22
permit tcp host 10.154.137.228 10.174.32.0 0.0.0.255 eq 3389
permit tcp host 10.154.137.228 10.174.32.0 0.0.0.255 eq www
permit tcp host 10.154.137.228 10.174.32.0 0.0.0.255 eq 443
permit tcp host 10.154.137.228 10.174.32.0 0.0.0.255 eq 22
permit udp host 10.174.49.230 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.174.5.230 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.171.11.1 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62070
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62072
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62074
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62076
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62077
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62078
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62079
permit tcp host 10.174.39.216 10.174.36.0 0.0.0.255 eq 62048
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq www
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62070
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62072
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62074
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62076
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62077
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62078
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62079
permit tcp host 10.174.39.216 10.174.32.0 0.0.0.255 eq 62048
permit tcp host 10.174.39.216 host 10.174.36.18 eq 2001
permit tcp host 10.174.39.216 host 10.174.36.19 eq 2001
permit tcp host 10.174.39.216 host 10.174.36.18 eq 2011
permit tcp host 10.174.39.216 host 10.174.36.19 eq 2011
permit tcp host 10.174.39.216 host 10.174.36.17 eq 1433
permit tcp host 10.174.39.216 host 10.174.36.17 eq 7774
permit tcp host 10.174.39.216 host 10.174.36.17 eq www
permit tcp host 10.174.39.216 host 10.174.36.4 range 1539 1541
permit udp host 10.174.5.83 host 10.174.36.17 eq 52311
permit udp host 10.174.47.172 host 10.174.36.17 eq 52311
permit udp host 10.152.41.58 host 10.174.36.17 eq 52311
permit tcp 10.140.53.0 0.0.0.255 host 10.174.36.3 eq 5712
permit tcp 10.140.52.0 0.0.0.255 host 10.174.36.3 eq 5712
permit tcp 10.140.51.0 0.0.0.255 host 10.174.36.3 eq 5712
permit tcp 10.140.44.0 0.0.0.255 host 10.174.36.3 eq 5712
permit tcp 10.152.49.0 0.0.0.255 host 10.174.36.3 eq 5712
permit tcp 10.228.10.0 0.0.0.255 host 10.174.36.3 eq 5712
permit tcp 10.229.10.0 0.0.0.255 host 10.174.36.3 eq 5712
permit icmp host 10.174.50.40 host 10.174.36.121 echo
permit icmp host 10.174.50.60 host 10.174.36.121 echo
permit icmp host 10.174.39.216 host 10.174.36.121 echo
permit icmp host 10.174.50.40 host 10.174.36.122 echo
permit icmp host 10.174.50.60 host 10.174.36.122 echo
permit icmp host 10.174.39.216 host 10.174.36.122 echo
permit icmp host 10.174.50.40 host 10.174.36.123 echo
permit icmp host 10.174.50.60 host 10.174.36.123 echo
permit icmp host 10.174.39.216 host 10.174.36.123 echo
permit icmp host 10.174.50.40 host 10.174.36.124 echo
permit icmp host 10.174.50.60 host 10.174.36.124 echo
permit icmp host 10.174.39.216 host 10.174.36.124 echo
permit icmp host 10.174.50.40 host 10.174.36.125 echo
permit icmp host 10.174.50.60 host 10.174.36.125 echo
permit icmp host 10.174.39.216 host 10.174.36.125 echo
permit icmp host 10.174.50.40 host 10.174.36.126 echo
permit icmp host 10.174.50.60 host 10.174.36.126 echo
permit icmp host 10.174.39.216 host 10.174.36.126 echo
permit udp host 10.171.182.136 10.174.36.0 0.0.0.255 eq snmp
permit udp host 10.171.180.136 10.174.36.0 0.0.0.255 eq snmp
permit udp host 10.171.182.136 10.174.32.0 0.0.0.255 eq snmp
permit udp host 10.171.180.136 10.174.32.0 0.0.0.255 eq snmp
permit udp host 10.172.253.3 10.174.36.0 0.0.0.255 eq snmp
permit udp host 10.171.215.3 10.174.36.0 0.0.0.255 eq snmp
permit udp host 10.172.253.3 10.174.32.0 0.0.0.255 eq snmp
permit udp host 10.171.215.3 10.174.32.0 0.0.0.255 eq snmp
permit udp host 10.171.180.136 10.174.36.0 0.0.0.255 eq snmptrap
permit udp host 10.171.182.136 10.174.36.0 0.0.0.255 eq snmptrap
permit udp host 10.171.180.136 10.174.32.0 0.0.0.255 eq snmptrap
permit udp host 10.171.182.136 10.174.32.0 0.0.0.255 eq snmptrap
permit udp host 10.172.253.3 10.174.36.0 0.0.0.255 eq snmptrap
permit udp host 10.171.215.3 10.174.36.0 0.0.0.255 eq snmptrap
permit udp host 10.172.253.3 10.174.32.0 0.0.0.255 eq snmptrap
permit udp host 10.171.215.3 10.174.32.0 0.0.0.255 eq snmptrap
permit tcp host 10.171.195.13 10.174.36.0 0.0.0.255 eq 5600
permit tcp host 10.171.195.13 10.174.36.0 0.0.0.255 eq 5601
permit tcp host 10.239.10.15 10.174.36.0 0.0.0.255 eq 5600
permit tcp host 10.239.10.15 10.174.36.0 0.0.0.255 eq 5601
permit tcp host 10.171.195.13 10.174.32.0 0.0.0.255 eq 5600
permit tcp host 10.171.195.13 10.174.32.0 0.0.0.255 eq 5601
permit tcp host 10.239.10.15 10.174.32.0 0.0.0.255 eq 5600
permit tcp host 10.239.10.15 10.174.32.0 0.0.0.255 eq 5601
permit udp host 10.171.55.201 10.174.36.0 0.0.0.255 eq ntp
permit udp host 10.234.55.201 10.174.36.0 0.0.0.255 eq ntp
permit udp host 10.239.1.22 10.174.36.0 0.0.0.255 eq ntp
permit udp host 10.171.199.201 10.174.36.0 0.0.0.255 eq ntp
permit tcp host 10.153.50.76 10.174.36.0 0.0.0.255 eq 52311
permit tcp host 10.153.50.76 10.174.36.0 0.0.0.255 eq 52312
permit tcp host 10.153.50.76 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.152.41.58 10.174.36.0 0.0.0.255 eq 52311
permit tcp host 10.152.41.58 10.174.36.0 0.0.0.255 eq 52312
permit tcp host 10.152.41.58 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.153.242.29 10.174.36.0 0.0.0.255 eq 52311
permit tcp host 10.153.242.29 10.174.36.0 0.0.0.255 eq 52312
permit tcp host 10.153.242.29 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.152.189.140 10.174.36.0 0.0.0.255 eq 52311
permit tcp host 10.152.189.140 10.174.36.0 0.0.0.255 eq 52312
permit tcp host 10.152.189.140 10.174.36.0 0.0.0.255 eq www
permit tcp host 10.174.5.51 10.174.36.0 0.0.0.255 eq 52311
permit tcp host 10.174.5.51 10.174.36.0 0.0.0.255 eq 52312
permit tcp host 10.174.5.51 10.174.36.0 0.0.0.255 eq www
permit udp host 10.153.50.76 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.152.41.58 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.152.242.29 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.152.189.140 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.174.5.51 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.153.50.76 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.153.50.76 10.174.36.0 0.0.0.255 eq 52312
permit udp host 10.152.41.58 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.152.41.58 10.174.36.0 0.0.0.255 eq 52312
permit udp host 10.153.242.29 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.153.242.29 10.174.36.0 0.0.0.255 eq 52312
permit udp host 10.152.189.140 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.152.189.140 10.174.36.0 0.0.0.255 eq 52312
permit udp host 10.174.5.51 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.174.5.51 10.174.36.0 0.0.0.255 eq 52312
permit icmp host 10.153.50.76 10.174.36.0 0.0.0.255 echo
permit icmp host 10.152.41.58 10.174.36.0 0.0.0.255 echo
permit icmp host 10.152.242.29 10.174.36.0 0.0.0.255 echo
permit icmp host 10.152.189.140 10.174.36.0 0.0.0.255 echo
permit icmp host 10.174.5.51 10.174.36.0 0.0.0.255 echo
permit icmp host 10.153.50.76 10.174.36.0 0.0.0.255 echo-reply
permit icmp host 10.152.41.58 10.174.36.0 0.0.0.255 echo-reply
permit icmp host 10.153.242.29 10.174.36.0 0.0.0.255 echo-reply
permit icmp host 10.152.189.140 10.174.36.0 0.0.0.255 echo-reply
permit icmp host 10.174.5.51 10.174.36.0 0.0.0.255 echo-reply
permit tcp host 10.173.160.105 10.174.36.0 0.0.0.255 eq 7071
permit tcp host 10.173.160.108 10.174.36.0 0.0.0.255 eq 7071
permit tcp host 10.173.160.104 10.174.36.0 0.0.0.255 eq 7071
permit tcp host 10.173.160.101 10.174.36.0 0.0.0.255 eq 7071
permit tcp host 10.173.160.106 10.174.36.0 0.0.0.255 eq 7071
permit tcp host 10.173.160.103 10.174.36.0 0.0.0.255 eq 7071
permit tcp host 10.171.196.73 10.174.36.0 0.0.0.255 eq 7071
permit tcp host 10.174.5.138 10.174.36.0 0.0.0.255 eq 1500
permit tcp host 10.174.5.138 10.174.36.0 0.0.0.255 eq 1502
permit tcp host 10.174.47.222 10.174.36.0 0.0.0.255 eq 1500
permit tcp host 10.174.47.222 10.174.36.0 0.0.0.255 eq 1502
permit tcp host 10.174.49.149 10.174.36.0 0.0.0.255 eq 1500
permit tcp host 10.174.49.149 10.174.36.0 0.0.0.255 eq 1502
permit tcp host 10.174.12.68 10.174.36.0 0.0.0.255 eq 1500
permit tcp host 10.174.12.68 10.174.36.0 0.0.0.255 eq 1502
permit tcp host 10.232.65.69 host 10.174.36.6 eq 5000
permit tcp host 10.235.16.9 host 10.174.36.6 eq 5000
permit tcp host 10.232.65.69 host 10.174.36.6 eq 443
permit tcp host 10.235.16.9 host 10.174.36.6 eq 443
permit tcp 10.128.56.0 0.0.0.255 host 10.174.36.6 eq 5000
permit tcp 10.128.56.0 0.0.0.255 host 10.174.36.6 eq 443
permit tcp 10.170.211.0 0.0.0.255 host 10.174.36.6 eq 5000
permit tcp 10.170.211.0 0.0.0.255 host 10.174.36.6 eq 443
permit tcp 10.170.212.0 0.0.0.255 host 10.174.36.6 eq 5000
permit tcp 10.170.212.0 0.0.0.255 host 10.174.36.6 eq 443
permit tcp host 10.174.39.216 host 10.174.36.6 eq 5000
permit tcp host 10.174.39.216 host 10.174.36.6 eq 443
permit tcp host 10.174.50.60 host 10.174.36.6 eq 5000
permit tcp host 10.174.50.60 host 10.174.36.6 eq 443
permit tcp host 10.174.50.40 host 10.174.36.6 eq 5000
permit tcp host 10.174.50.40 host 10.174.36.6 eq 443
permit udp host 10.232.65.69 host 10.174.36.6 eq 5000
permit udp host 10.235.16.9 host 10.174.36.6 eq 5000
permit udp host 10.232.65.69 host 10.174.36.6 gt 1024
permit udp host 10.235.16.9 host 10.174.36.6 gt 1024
permit udp host 10.174.39.216 host 10.174.36.19 eq 2000
permit udp host 10.174.39.216 host 10.174.36.18 eq 2000
permit tcp 10.170.104.0 0.0.0.255 host 10.174.36.6 eq www
permit tcp 10.170.104.0 0.0.0.255 host 10.174.36.6 eq 433
permit tcp 10.170.104.0 0.0.0.255 host 10.174.36.6 eq 3381
permit tcp host 10.242.132.145 host 10.174.36.6 eq www
permit tcp host 10.242.132.145 host 10.174.36.6 eq 433
permit tcp host 10.242.132.145 host 10.174.36.6 eq 3381
permit tcp host 10.242.132.147 host 10.174.36.6 eq www
permit tcp host 10.242.132.147 host 10.174.36.6 eq 433
permit tcp host 10.242.132.147 host 10.174.36.6 eq 3381
permit tcp host 10.242.133.145 host 10.174.36.6 eq www
permit tcp host 10.242.133.145 host 10.174.36.6 eq 433
permit tcp host 10.242.133.145 host 10.174.36.6 eq 3381
permit tcp host 10.242.133.147 host 10.174.36.6 eq www
permit tcp host 10.242.133.147 host 10.174.36.6 eq 433
permit tcp host 10.242.133.147 host 10.174.36.6 eq 3381
permit udp host 10.174.36.19 host 10.182.108.221 gt 1024
permit udp host 10.174.36.19 host 10.182.108.223 gt 1024
permit tcp host 10.174.25.100 host 10.174.36.21 eq 2011
permit tcp host 10.174.25.100 host 10.174.36.21 eq 2001
permit tcp host 10.174.39.216 host 10.174.36.21 eq 2011
permit tcp host 10.174.39.216 host 10.174.36.21 eq 2001
permit tcp host 10.182.108.221 host 10.174.36.21 eq 2011
permit tcp host 10.182.108.221 host 10.174.36.21 eq 2001
permit tcp host 10.182.108.223 host 10.174.36.21 eq 2011
permit tcp host 10.182.108.223 host 10.174.36.21 eq 2001
permit udp host 10.174.25.100 host 10.174.36.21 eq 2000
permit udp host 10.174.39.216 host 10.174.36.21 eq 2000
permit udp host 10.182.108.221 host 10.174.36.21 eq 2000
permit udp host 10.182.108.223 host 10.174.36.21 eq 2000
permit udp host 10.174.250.75 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.242.160.75 10.174.36.0 0.0.0.255 gt 1024
permit udp host 10.174.250.75 10.174.32.0 0.0.0.255 gt 1024
permit udp host 10.242.160.75 10.174.32.0 0.0.0.255 gt 1024
permit tcp 172.23.0.0 0.0.255.255 10.174.36.0 0.0.0.255
permit tcp 172.23.0.0 0.0.255.255 10.174.32.0 0.0.0.255
permit udp host 10.182.54.20 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.182.54.112 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.182.54.113 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.182.60.222 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.242.160.96 10.174.36.0 0.0.0.255 eq 52311
permit udp host 10.242.162.109 10.174.36.0 0.0.0.255 eq 52311
permit tcp host 10.152.41.58 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.182.54.20 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.182.54.112 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.182.54.113 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.182.60.222 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.242.160.96 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.242.162.109 10.174.36.0 0.0.0.255 gt 1024
permit icmp host 10.182.54.20 10.174.36.0 0.0.0.255
permit icmp host 10.182.54.112 10.174.36.0 0.0.0.255
permit icmp host 10.182.54.113 10.174.36.0 0.0.0.255
permit icmp host 10.182.60.222 10.174.36.0 0.0.0.255
permit icmp host 10.242.160.96 10.174.36.0 0.0.0.255
permit icmp host 10.242.162.109 10.174.36.0 0.0.0.255
permit tcp host 10.235.35.29 host 10.174.36.1 eq 22
permit tcp host 10.235.35.29 host 10.174.36.1 eq 1543
permit tcp host 10.235.35.29 host 10.174.36.1 eq www
permit tcp host 10.235.35.29 host 10.174.36.1 eq 443
permit tcp host 10.240.67.21 host 10.174.36.1 eq 22
permit tcp host 10.240.67.21 host 10.174.36.1 eq 1543
permit tcp host 10.240.67.21 host 10.174.36.1 eq www
permit tcp host 10.240.67.21 host 10.174.36.1 eq 443
permit tcp host 10.235.35.29 host 10.174.36.1 gt 1024
permit udp host 10.235.35.29 host 10.174.36.1 gt 1024
permit tcp host 10.235.35.29 10.174.32.0 0.0.0.255 gt 1024
permit tcp host 10.240.67.21 10.174.36.0 0.0.0.255 gt 1024
permit tcp host 10.240.67.21 host 10.174.36.1 gt 1024
permit tcp host 10.170.177.203 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.180.109.57 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.182.54.21 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.242.164.3 10.174.36.0 0.0.0.255 eq 3389
permit icmp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255
permit udp 10.182.215.0 0.0.0.15 eq 5030 10.174.36.0 0.0.0.255
permit udp 10.182.215.0 0.0.0.15 eq 5032 10.174.36.0 0.0.0.255
permit icmp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 echo
permit tcp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 eq 22
permit tcp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 eq 443
permit tcp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 eq 8800
permit udp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 eq 5030
permit udp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 eq 5032
permit udp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 eq syslog
permit udp 10.182.215.0 0.0.0.15 10.174.36.0 0.0.0.255 eq ntp
permit icmp 10.187.103.0 0.0.0.127 host 10.174.36.1
permit icmp 10.187.103.128 0.0.0.63 host 10.174.36.1
permit tcp 10.187.103.0 0.0.0.127 host 10.174.36.1 eq 22
permit tcp 10.187.103.128 0.0.0.63 host 10.174.36.1 eq 22
permit tcp 10.187.103.0 0.0.0.127 host 10.174.36.1 eq 443
permit tcp 10.187.103.128 0.0.0.63 host 10.174.36.1 eq 443
permit tcp 10.187.103.0 0.0.0.127 10.174.36.0 0.0.0.255 eq 8800
permit tcp 10.187.103.128 0.0.0.63 10.174.36.0 0.0.0.255 eq 8800
permit udp 10.187.103.0 0.0.0.127 10.174.36.0 0.0.0.255 eq 5032
permit udp 10.187.103.128 0.0.0.63 10.174.36.0 0.0.0.255 eq 5032
permit udp 10.187.103.0 0.0.0.127 10.174.36.0 0.0.0.255 eq 5030
permit udp 10.187.103.128 0.0.0.63 10.174.36.0 0.0.0.255 eq 5030
permit udp 10.187.103.0 0.0.0.127 10.174.36.0 0.0.0.255 eq syslog
permit udp 10.187.103.128 0.0.0.63 10.174.36.0 0.0.0.255 eq syslog
permit udp 10.187.103.0 0.0.0.127 10.174.36.0 0.0.0.255 eq ntp
permit udp 10.187.103.128 0.0.0.63 10.174.36.0 0.0.0.255 eq ntp
permit tcp 10.187.103.0 0.0.0.127 10.174.36.0 0.0.0.255 eq 443
permit tcp 10.187.103.128 0.0.0.63 10.174.36.0 0.0.0.255 eq 443
permit tcp 10.187.103.0 0.0.0.127 host 10.235.35.29 eq 443
permit tcp 10.187.103.128 0.0.0.63 host 10.235.35.29 eq 443
permit tcp 10.187.103.0 0.0.0.127 host 10.240.67.21 eq 443
permit tcp 10.187.103.128 0.0.0.63 host 10.240.67.21 eq 443
permit udp host 10.187.103.125 host 10.171.196.1 eq bootps
permit udp host 10.187.103.126 host 10.171.196.1 eq bootps
permit udp host 10.187.103.190 host 10.171.196.1 eq bootps
permit udp host 10.187.103.191 host 10.171.196.1 eq bootps
permit udp host 10.187.103.125 host 10.174.250.75 eq bootps
permit udp host 10.187.103.126 host 10.174.250.75 eq bootps
permit udp host 10.187.103.190 host 10.174.250.75 eq bootps
permit udp host 10.187.103.191 host 10.174.250.75 eq bootps
permit udp host 10.187.103.125 host 10.239.1.1 eq bootps
permit udp host 10.187.103.126 host 10.239.1.1 eq bootps
permit udp host 10.187.103.190 host 10.239.1.1 eq bootps
permit udp host 10.187.103.191 host 10.239.1.1 eq bootps
permit udp host 10.187.103.125 host 10.242.160.75 eq bootps
permit udp host 10.187.103.126 host 10.242.160.75 eq bootps
permit udp host 10.187.103.190 host 10.242.160.75 eq bootps
permit udp host 10.187.103.191 host 10.242.160.75 eq bootps
permit udp 10.187.103.0 0.0.0.127 eq 5032 10.174.36.0 0.0.0.255
permit udp 10.187.103.128 0.0.0.63 eq 5032 10.174.36.0 0.0.0.255
permit udp 10.187.103.0 0.0.0.127 eq 5030 10.174.36.0 0.0.0.255
permit udp 10.187.103.128 0.0.0.63 eq 5030 10.174.36.0 0.0.0.255
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq www
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq www
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq www
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq www
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62070
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62070
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62070
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62070
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62072
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62072
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62072
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62072
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62074
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62074
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62074
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62074
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62076
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62076
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62076
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62076
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62077
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62077
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62077
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62077
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62078
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62078
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62078
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62078
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62079
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62079
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62079
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62079
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.20 eq 62048
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.20 eq 62048
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.20 eq 62048
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.20 eq 62048
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.18 eq 2001
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.18 eq 2001
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.18 eq 2001
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.18 eq 2001
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.19 eq 2001
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.19 eq 2001
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.19 eq 2001
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.19 eq 2001
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.21 eq 2001
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.21 eq 2001
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.21 eq 2001
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.21 eq 2001
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.18 eq 2011
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.18 eq 2011
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.18 eq 2011
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.18 eq 2011
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.19 eq 2011
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.19 eq 2011
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.19 eq 2011
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.19 eq 2011
permit tcp 10.182.216.0 0.0.0.255 host 10.174.36.21 eq 2011
permit tcp 10.182.217.0 0.0.0.255 host 10.174.36.21 eq 2011
permit tcp 10.182.222.0 0.0.0.255 host 10.174.36.21 eq 2011
permit tcp 10.182.223.0 0.0.0.255 host 10.174.36.21 eq 2011
permit udp 10.182.216.0 0.0.0.255 host 10.174.36.18 eq 2000
permit udp 10.182.217.0 0.0.0.255 host 10.174.36.18 eq 2000
permit udp 10.182.222.0 0.0.0.255 host 10.174.36.18 eq 2000
permit udp 10.182.223.0 0.0.0.255 host 10.174.36.18 eq 2000
permit udp 10.182.216.0 0.0.0.255 host 10.174.36.19 eq 2000
permit udp 10.182.217.0 0.0.0.255 host 10.174.36.19 eq 2000
permit udp 10.182.222.0 0.0.0.255 host 10.174.36.19 eq 2000
permit udp 10.182.223.0 0.0.0.255 host 10.174.36.19 eq 2000
permit udp 10.182.216.0 0.0.0.255 host 10.174.36.21 eq 2000
permit udp 10.182.217.0 0.0.0.255 host 10.174.36.21 eq 2000
permit udp 10.182.222.0 0.0.0.255 host 10.174.36.21 eq 2000
permit udp 10.182.223.0 0.0.0.255 host 10.174.36.21 eq 2000
permit tcp host 10.164.177.44 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.164.177.45 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.164.92.23 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.164.92.24 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.208.28.16 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.208.28.17 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.235.159.23 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.235.159.24 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.239.54.65 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.239.54.66 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.240.78.52 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.240.78.53 10.174.36.0 0.0.0.255 eq 3389
permit tcp host 10.164.177.44 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.164.177.45 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.164.92.23 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.164.92.24 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.208.28.16 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.208.28.17 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.235.159.23 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.235.159.24 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.239.54.65 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.239.54.66 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.240.78.52 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 10.240.78.53 10.174.36.0 0.0.0.255 eq 9473
permit tcp host 172.23.64.193 10.174.36.0 0.0.0.255 eq 4750
permit tcp host 172.23.64.194 10.174.36.0 0.0.0.255 eq 4750
permit tcp host 172.23.64.195 10.174.36.0 0.0.0.255 eq 4750
permit tcp host 172.23.64.196 10.174.36.0 0.0.0.255 eq 4750
permit tcp host 172.23.66.193 10.174.36.0 0.0.0.255 eq 4750
permit tcp host 172.23.66.194 10.174.36.0 0.0.0.255 eq 4750
permit tcp host 172.23.66.195 10.174.36.0 0.0.0.255 eq 4750
permit tcp host 172.23.66.196 10.174.36.0 0.0.0.255 eq 4750
deny   ip any 10.174.36.0 0.0.0.255 log
deny   ip any 10.174.32.0 0.0.0.255 log
deny   ip any any log
ip sla enable reaction-alerts
logging history size 50
logging source-interface Loopback0
logging 10.233.125.250
logging 10.237.125.250
access-list 83 permit 10.233.225.1
access-list 83 permit 10.153.128.1
access-list 83 permit 10.140.76.234
access-list 83 permit 10.233.127.0 0.0.0.255
access-list 83 permit 10.237.127.0 0.0.0.255
access-list 83 permit 10.242.240.0 0.0.15.255
access-list 83 permit 10.9.0.0 0.0.31.255
access-list 83 deny   any log
access-list 85 permit 10.140.166.0 0.0.0.255
access-list 85 permit 10.140.175.0 0.0.0.255
access-list 85 permit 10.143.50.0 0.0.0.255
access-list 85 permit 10.153.128.0 0.0.0.255
access-list 85 permit 10.153.129.0 0.0.0.255
access-list 85 permit 10.159.231.0 0.0.0.255
access-list 85 permit 10.159.233.0 0.0.0.255
access-list 85 permit 10.171.55.0 0.0.0.255
access-list 85 permit 10.176.13.0 0.0.0.255
access-list 85 permit 10.177.13.0 0.0.0.255
access-list 85 permit 10.233.124.0 0.0.1.255
access-list 85 permit 10.233.127.0 0.0.0.255
access-list 85 permit 10.233.225.0 0.0.0.255
access-list 85 permit 10.234.55.0 0.0.0.255
access-list 85 permit 10.237.124.0 0.0.1.255
access-list 85 permit 10.237.127.0 0.0.0.255
access-list 85 permit 10.242.240.0 0.0.15.255
access-list 85 permit 10.9.0.0 0.0.31.255
access-list 85 deny   any log
access-list 86 permit 10.233.125.0 0.0.0.255
access-list 86 permit 10.237.125.0 0.0.0.255
access-list 86 deny   any log
access-list 98 permit any
access-list 99 deny   any
access-list 103 deny   ip any any log
no cdp run
snmp-server trap-source Loopback0
snmp-server packetsize 1450
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps bgp
snmp-server enable traps config
snmp-server enable traps hsrp
snmp-server enable traps stpx root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps rtr
snmp-server host 10.233.125.250 dmz
snmp-server host 10.237.125.250 dmz
tacacs-server host 10.233.125.250
tacacs-server host 10.237.125.250
tacacs-server timeout 20
no tacacs-server directed-request
tacacs-server key 7 14141B180F0B
line con 0
session-timeout 20
exec-timeout 20 0
line vty 0 4
session-timeout 20
access-class 85 in
exec-timeout 20 0
transport preferred none
transport input ssh
transport output ssh
line vty 5 15
access-class 85 in
no exec
transport input none
ntp clock-period 36028836
ntp source Loopback0
ntp access-group peer 86
ntp server 10.233.125.250 prefer
ntp server 10.237.125.250
end
Thanks in Advance
Umesh Shetty
Hello Umesh,
I also apologize for responding after such a delay.
I  indeed do not see any explicit QoS-related ACLs. My only guess is that  there is some QoS-related programming in the TCAM present because of the  mls qos trust dscp command on one of your ports. Otherwise, I am not sure.
Best regards,
Peter
HI,
In case of 45xx switch, we can change the TCAM also
Let me check for 3750 switch & update
Br/Subhojit
536
