teaming nic cards
Hello, Is there any extra switch commands on 6509 switch you have to configure when teaming two nic cards?
Green
Horacio, The answer depends
Horacio,
The answer depends on whether your team will be load balanced or just in Network fault tolerance
Have a look at this link:-
http://www.cisco.com/c/en/us/support/docs/lan-switching/etherchannel/98469-ios-etherchannel.html
Alex
Regards, Alex. Please rate useful posts.
So if I need the nics teamed
So if I need the nics teamed to have more bandwidth you have to configure the ethernet channel ports, correct?
VIP Super Bronze
Is not more bandwidth but
Is not more bandwidth but rather load balances traffic between multiple links.  So, lets say you have 2 links in a Portchannel and 2 PCs sending traffic.  The first PC will use one of the link in the Portchannle and the other PC will use the other link. So, the traffic from multiple hosts will use multiple links.
39
