Community Member
Telnet - 6500 pass thru
Here is what I am trying to achieve:
- set up a restricted user on the 6500
- allow the user to connect via telnet to the 6500, and only be able to telnet/ssh to a remote PIX.
- I do not wish for the user to have any other visibility within the 6500, only use the 6500 as a telnet/ssh platform to the PIX
Is this possible. If so, how might I achieve this objective?
thx,
Jim
1 REPLY
Hall of Fame Super Bronze
Re: Telnet - 6500 pass thru
Jim,
You can use the autocommand option under the username string if using local authentication.
Please see:
http://www.cisco.com/en/US/docs/ios/11_2/security/command/reference/2rauthen.html
For TACACS, the configuration needs to be done in the TACACS device and I suggest asking in the network management portion of this forum on that task.
HTH,
__
Edison.
123
