10-16-2008 11:53 PM - edited 03-06-2019 01:59 AM
The problem is that I can not telnet to a switch, even though I can traceroute to it from my PC. Moreover, I can telnet to that switch from the switch my PC is connected to. Can not understand, where the trick is..
10-17-2008 12:01 AM
Are you saying you cannot telnet to the switch from the PC,but from the switch you are able to.
Are u able to telnet to the switch where your laptop is connected.
What vlan is your PC in .
10-17-2008 12:11 AM
Yes
vlan 2
All communication goes over Layer 3
10-17-2008 12:02 AM
If you can ping and traceroute the switch IP and have verified telnet works we can conclude the problem is above OSI layer 3.
So I would check:
1) telnet application works in the PC
2) personal FW (or the like) on the PC preventing telnet
3) FW between PC and switch
4) access restrictions for telnet in the switch (like ACL applied to VTY lines)
Hope this helps! Please use the rating system.
Martin
10-17-2008 12:12 AM
1) I can telnet to any other switch, so I assume it works fine
2) FW is disabled
3) Disabled
4) No IP access lists defined
10-17-2008 12:19 AM
I apologize, I forgot to disable Firewall Client
