Telnet session lockout very first
Hi All,
I am facing one problem that one of my switch ( 2960 ) telnet session lock off very first, Its only allow to login around 5-7 seconds,
Below is my current config,
line vty 0 4
exec-timeout 5 0
logging synchronous
login local
line vty 5 15
exec-timeout 5 0
logging synchronous
login local
I have add following in global config mode, but not help.
service tcp-keepalives-in
service tcp-keepalives-out
Appricate someone look into it.
Everyone's tags (2)
Purple
so your session is disconnected after 5 secs ? It shouldn't as the exec-timeout is configured at 5 mins.
Can you post your config.
Regards.
Alain
Re: Telnet session lockout very first
Hi Alain, thanks for help
Hear is config,
version 12.2
no service pad
service password-encryption
hostname xxxxx
boot-start-marker
boot-end-marker
enable password 7 xxxxx
username xxxx password 7 xxxxx
no aaa new-model
system mtu routing 1500
vtp mode transparent
ip subnet-zero
crypto pki trustpoint TP-self-signed-3401816704
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3401816704
revocation-check none
rsakeypair TP-self-signed-3401816704
crypto pki certificate chain TP-self-signed-3401816704
certificate self-signed 01
  30820242 308201AB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 21
interface GigabitEthernet0/1
switchport access vlan xx
switchport mode access
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
interface Vlan21
ip address 192.168.xxx.xxx 255.255.255.0
no ip route-cache
ip default-gateway 192.168.xxx.xxx
ip http server
ip http secure-server
control-plane
line con 0
exec-timeout 5 0
logging synchronous
login local
line vty 0 4
exec-timeout 5 0
logging synchronous
login local
line vty 5 15
exec-timeout 5 0
logging synchronous
login local
# Update
change to
# exec-timeout 0 0
not help!!
Message was edited by: KYAW ZIN OO
#Latest update.
I can login from another switch with stable,
don't know what happen that this issue happen once telnet from server.
643
