10-01-2008 12:32 PM - edited 03-06-2019 01:42 AM
I am unable to telnet to a personal computer running Windows XP Home edition.
The connection is being denied. I am able to ping this computer. The firewall on the computer has been turned off.
Solved! Go to Solution.
10-01-2008 12:34 PM
Not particularly a Cisco question but :)
AFAIK windows XP Home edition does not run a telnet server so you won't be able to telnet to it.
XP has a telnet client so you can telnet FROM the machine but unless you install a telnet server onto the XP machines you won't be able to telnet to it.
Jon
10-01-2008 12:42 PM
if you need to use telnet, perhaps try this one:
10-01-2008 12:34 PM
Jon
10-01-2008 12:42 PM
