Telnet to FTP Server
cisconoval
Is it possible to telnet Port 21 from router's FastEthernet port. If so please advice how to do that.
Thanks in Advance
network.king
Level 4
Level 4
You can just check whether FTP service is running in the machine you try
Router#telnet x.x.x.x 21 /source-interface fa0
If you get a open ... then port is fine in the server , but you also need to check wheter permissions for your fast ethernet ip is given.
otherwise application might not be working , or may be permissions for ur fastethernet ip might not be given or a route for ur fastethernet might not be available..
regards
vanesh k
Thanks for your reply. I tried the extended tracert with port 21, it was through.
but when I tried as you said its vain.
any suggestion how to chk the permission as you said. Sorry I am new to cisco...please
First test by telnetting to any internet sites on port 80 to just verify there is no issues with routing part of your fast ethernet
telnet www.yahoo.com 80 /source-interface fa0
If its fine , then check with the server admin wheter ftp is open to all or only to restricted users .If to restricted users , pls ask him to give the permission for your ip .If there is no access restriction there might be restriction in the Firewall , Ask ur FW admin to give access to ur ip.
pls check and let me know the results
regards
vanesh k
