Webcast-Catalyst9k
Test SFPs in 3560
Does anyone know of a way to test an sfp in a 3560?
I have a single mode connection and as soon as I try to ping or put any amount of data on the circuit it starts dropping.  I have talked with the people that have provided the circuit and they said they are seeing errors between their connection and our switch.  So I was trying to see if you can test the sfp...
Hall of Fame Super Gold
Re: Test SFPs in 3560
Just place a patch cord across the connectors.
Errors are isually due to faulty circuit splices, not equipment.
So whta should be put in loopback and tested first is the circuit, not the equipment.
Thank you. I appreciate your response.
VIP Super Bronze
Hi Brenda,
Since your fiber is single-mode make sure your SFP is also single mode.  Also try using a spare one in the same slot (if you have one).  Also make sure the tips of the connector are clean before before you insert the LC fiber patch cord into the SFP slot.
Reza
168
