TFTP & Sample configuration
I need advice and steps on how to configure a TFTP Server and load the configuration and IOS from it for all Routers on the Network.
Which TFTP server would you advice.
Is there any cisco document with step-by-step configuration.
1 ACCEPTED SOLUTION
Re: TFTP & Sample configuration
That's why i SAID "I recommend using an external tftp server such as tftpd32".
I recommend using an external tftp server such as tftpd32. You may configure a router to be a tftp server, here is the procedure:
http://www.cisco.com/en/US/docs/ios/12_2/configfun/configuration/guide/fcf011_ps1835_TSD_Products_Configuration_Guide_Chapter.html#wp1000912
Thanks..
I have 25 routers on the network and feel wont be a good idea to configure a dedicated router to send Router-config to all 25 routers...
I am looking for a practical working scenario for this request.....
244
