The channel-protocol command - what purpose does it serve?
Kevin Dorrell
Level 10
Level 10
I have been playing with channel negotiation protocols in the lab, and I am struggling to understand what useful purpose the channel-protocol command serves.
If you are in modes desirable or auto, you can only handle a PAgP parter anyway. If you are in modes active or passive, you can only handle an LACP partner anyway. If you are in mode on you can negotiate neither PAgP nor LACP. So isn't the protocol always implicit in the mode?
So what does the channel-protocol command do? As far as I can see in the lab, the only thing it does is to restrict you configuration options to desirable and/or auto, or active and/or passive. A sort of "belt and braces".
Is there some scenario I have not tested, where is serves some functional purpose?
Kevin Dorrell
Luxembourg
Edison Ortiz
That's exactly it. If you were to configure active/active or active/passive with the channel-protocol set to PAgP, the etherchannel wouldn't form. Same goes the other way around.
I guess is an assurance that you are indeed using the correct etherchannel protocol :)
__
Edison.
Edison Ortiz
__
Edison.
Edison, thank you for confirming that. In fact, my lab session showed that if you set the channel-protocol to PAgP, then it will not even allow you to configure mode active or passive - it rejects the command. And vice versa.
Kevin Dorrell
Luxembourg
