07-17-2008 10:02 AM - edited 03-06-2019 12:15 AM
Hi.
I'm using Cisco Network Assistant. and under View > System Messages i'm recieving this :
Description: Interface GigabitEthernet0/10, changed state to down
Explanation: The interface hardware went either up or down.
Recommended Action: If the state change was unexpected, confirm the configuration settings\n\ for the interface.
This port is attached to one of my critical servers and i always need this port to be up. any help please.
07-17-2008 10:19 AM
This could be caused by a million reasons so the question here is, Do you have access to that device in order to gather the show log and the show int gig0/10.
With the information provided is almost impossible to "guess" what is going on.
07-17-2008 10:48 AM
this is the output:
ES-SW15#sh interfaces gigabitEthernet 0/19
GigabitEthernet0/19 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0015.c64d.8c13 (bia 0015.c64d.8c13)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
35163364 packets input, 824030934 bytes, 0 no buffer
Received 505332 broadcasts (0 multicast)
0 watchdog, 54 multicast, 0 pause input
55486702 packets output, 961910359 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
07-17-2008 10:54 AM
Error message is pointing to int gig0/10, this is the output of 0/19 and this one looks very clean. Anything in the show log?
07-17-2008 11:03 AM
yes, as i'm having this error on multiple ports.
ES-SW15#sh log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes,
0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 396 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 396 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Trap logging: level informational, 399 message lines logged
Log Buffer (4096 bytes):
07:57: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/10, chan
ged state to down
000361: *Jul 26 10:07:58: %LINK-3-UPDOWN: Interface GigabitEthernet0/10, changed
state to down
000362: *Jul 26 10:12:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
tEthernet0/19, changed state to down
000363: *Jul 26 10:12:26: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to down
000364: *Jul 26 10:12:32: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to up
000365: *Jul 26 10:12:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
tEthernet0/19, changed state to up
000366: *Jul 26 10:13:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000367: *Jul 26 10:13:09: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to down
000368: *Jul 26 10:13:11: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to up
000369: *Jul 26 10:13:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000370: *Jul 27 17:38:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
tEthernet0/15, changed state to down
000371: *Jul 27 17:38:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
tEthernet0/14, changed state to down
000372: *Jul 27 17:38:01: %LINK-3-UPDOWN: Interface GigabitEthernet0/15, changed
state to down
000373: *Jul 27 17:38:01: %LINK-3-UPDOWN: Interface GigabitEthernet0/14, changed
state to down
000374: *Jul 27 17:38:03: %LINK-3-UPDOWN: Interface GigabitEthernet0/15, changed
state to up
000375: *Jul 27 17:38:04: %LINK-3-UPDOWN: Interface GigabitEthernet0/14, changed
state to up
07-17-2008 11:03 AM
000376: *Jul 27 17:38:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
tEthernet0/15, changed state to up
000377: *Jul 27 17:38:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
tEthernet0/14, changed state to up
000378: *Jul 28 22:04:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000379: *Jul 28 22:04:24: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to down
000380: *Jul 28 22:04:30: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to up
000381: *Jul 28 22:04:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000382: *Jul 28 22:05:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000383: *Jul 28 22:05:07: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to down
000384: *Jul 28 22:05:09: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to up
000385: *Jul 28 22:05:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000386: *Aug 3 17:33:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000387: *Aug 3 17:33:32: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to down
000388: *Aug 3 17:33:38: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to up
000389: *Aug 3 17:33:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000390: *Aug 3 17:34:13: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000391: *Aug 3 17:34:14: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to down
000392: *Aug 3 17:34:17: %LINK-3-UPDOWN: Interface GigabitEthernet0/19, changed
state to up
000393: *Aug 3 17:34:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi
000394: *Aug 3 18:25:19: %SYS-6-CLOCKUPDATE: System clock has been updated from
18:25:19 UTC Tue Aug 3 1993 to 21:25:19 MSK Tue Aug 3 1993, configured from con
sole by on console.
000395: *Aug 3 18:25:19: %SYS-6-CLOCKUPDATE: System clock has been updated from
21:25:19 MSK Tue Aug 3 1993 to 21:25:19 MSK Tue Aug 3 1993, configured from con
sole by on console.
000396: *Jul 17 17:42:00: %SYS-6-CLOCKUPDATE: System clock has been updated from
21:25:19 MSK Tue Aug 3 1993 to 20:42:00 MSK Thu Jul 17 2008, configured from co
nsole by on console.
ES-SW15#
07-17-2008 02:42 PM
hi again,
would it differ if i used the following command : no shutdown ?
would this command makes the port status always up ?
07-17-2008 06:10 PM
"no shutdown" will enable the port. "shutdown" will put the port into admin down state.
You might have a physical problem such as bad port on the server, cable problem, even bad port on the switch. If you have service contract, please contact Cisco TAC.
HTH,
jerry
