the problem with my catalyst 2950 serie
Hello! When l try to recocry the equipment this message appear: ''The system is unable to boot automatically.  The BOOT environment variable needs to be set to a bootable image.'' what can l do?
Thanks.
Try:http://www.cisco.com/c/en
Try:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
Tryconf tboot system flash:
Try
conf t
boot system flash:[IMAGE_NAME]
wr
reload
Replace [IMAGE_NAME] with the actual name of the IOS image within the flash
How to know if my equipment
How to know if my equipment have the ios image.
please find attached the picture appear.
thank.
Hall of Fame Super Gold
No IOS.   Refer to Inayath's
No IOS.
Refer to Inayath's link (below) about how to load the IOS back into your switch.
Hello mtchicmen
Hello mtchicmen
As in your output there are two files available in the flash memory i.e. "config.text" and "private-config.text" and there is no such file having an extension of .bin that is the file of IOS. So you have to install the IOS in your switch. You can follow the below process to install IOS in the switch. For installing IOS you can use Hyper Terminal or Tera Term.
First of all increase the console speed by using the command:
switch: set BAUD 115200
Then open the hyper terminal session by setting speed of 115200 instead of 9600.
Then you will get the switch: prompt.
switch: flash_init
switch: load_helper
switch: copy xmodem: flash:c2955-i6q4l2-mz.121-13.EA1.bin
Then click on transfer---- click on send file--- give the file path and select xmodem --- click on send. It will start copying the files from pc to switch. Then after copying it will automatically install IOS into the switch. When installing will complete you have to type "boot" command and you will get the access of switch.
Mukesh Kumar
Network Engineer
Spooster IT Services
hello,How can l do to have
hello,
How can l do to have the ios for my equipment? (catalyst 2950)
thank.
Hello mtchicmenYou have to
Hello mtchicmen
You have to contact with Cisco to purchase the IOS.
First of all you have to check which features do you require. Then you can check in Cisco Feature Navigator in which IOS image these features are available. Then you can purchase that IOS from Cisco.
Mukesh Kumar
Network Engineer
Hi, Please i need to know
Please i need to know what is "xmodem" ?
That is the only information i don't have now.
Hello mtchicmen"Xmodem" is a
Hello mtchicmen
"Xmodem" is a simple file transfer protocol that is used to transfer files. It is used to transfer the IOS files from pc to the router/switch. When we don't have TFTP server then we can use xmodem but pc must be directly connected to the router's console.
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/15085-xmodem-generic.html
Mukesh Kumar
Network Engineer
117
