Community Member
three questions about OSI/RM.
1. we all know MAC is short for media access control, which is used in Layer 2 , and only in IEEE802 standard system. in another type of network Frame Relay, we used Data Link Control Interface instead. so i guess that we use different tool to identify end-user. am i right?
2. Generally, WAN interface (serial interfaces) don't have a MAC address, and I want to know if the reason is I just mentioned before. and if that means all WAN interfaces don't need  MAC addresses.
3.what kind of application should used Frame Relay network?
Thank you for your answers!
1 REPLY
Highlighted
Hey,Regarding your questions
Hey,
Regarding your questions:
1. we all know MAC is short for media access control, which is used in Layer 2 , and only in IEEE802 standard system. in another type of network Frame Relay, we used Data Link Control Interface instead. so i guess that we use different tool to identify end-user. am i right? - End users or machines will always have a mac address.
2. Generally, WAN interface (serial interfaces) don't have a MAC address, and I want to know if the reason is I just mentioned before. and if that means all WAN interfaces don't need  MAC addresses - I suggest the following link, its a good read:https://supportforums.cisco.com/discussion/10236311/mac-address-serial-interface
3.what kind of application should used Frame Relay network? - Its used mostly used by ISP's only.
HTH.
RS.
44
