Throughput on a 5505
I have a 5505 with SUP3 and 24 10/100 blade , FE-TX blade and gigabit uplink module.
The best throughput I get is 45Mbits/s in the same blade. It traffic goes through the uplink module throughput drops to 25Mbits/s. Is it normal? I have two unit and they both performs the same. Tested with foundry and summit and got 80Mbits/s+ with the same stations.
Purple
Re: Throughput on a 5505
This is a very old switch circa 1997 and I believe total backplane capacity is only 1 gig so most likely you are oversubscribed and what you are seeing is normal.
Nope, I actually found out what the problem was. Just duplex mismatch! Throughput now is 11Mbytes/s!
196
