Silver
Throughput on Cisco 7140-2T3
I have a setup shown in the diagram. The speed and duplex are hard coded
on both the server and the Cisco 7140 and the switchport on the blade.
Servers are hard coded to 1000-full and Cisco 7140 is hard code to 100-full.
Same thing on the Catalyst 6506 blade.
When I performed iperf between linux_1 and linux_2, I get 890Mbps.
That is what I expected. However, when I performed iperf between linux_1
and Linux_3 or Linux2 and Linux_3, I only get about 30mbps throughput.
I thought that I should get much higher throughput than that, like
90Mpbs or something like that but I am maxing out at 30mbps.
Configuration on the Cisco 7140 is very simple:
interface F0/0
ip address 192.168.2.1 255.255.255.0 secondary
speed 100
duplex full
no shut
There is no other configuration on this device.
LAB>sh ver
IOS (tm) EGR Software (C7100-JO3S-M), Version 12.3(12e), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 24-Aug-05 15:44 by ssearch
Image text-base: 0x60008AF4, data-base: 0x6255C000
ROM: System Bootstrap, Version 12.0(5r)XE2, RELEASE SOFTWARE (fc1)
BOOTLDR: EGR Software (C7100-BOOT-M), Version 12.1(5a)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
LAB uptime is 7 weeks, 3 days, 19 hours, 5 minutes
System returned to ROM by reload at 21:47:23 UTC Tue Feb 5 2008
System restarted at 19:45:47 UTC Tue Feb 5 2008
System image file is "slot1:c7100-jo3s-mz.123-12e.bin"
Last reload reason: Reload command
cisco 7140-2T3 (EGR) processor (revision A) with 229376K/98304K bytes of memory.
Processor board ID xxxxx
R7000 CPU at 262MHz, Implementation 39, Rev 2.1, 256KB L2, 2048KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
125K bytes of non-volatile configuration memory.
16384K bytes of Flash PCMCIA card at slot 1 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
LAB>
Furthermore, CPU on the Cisco 7140 hit 100%
utilization. at 30mbps.
Is this "normal" on the Cisco 7140 at 30mpbs throughput? Thanks.
1 REPLY
Bronze
Re: Throughput on Cisco 7140-2T3
It is looking like the packets are getting encrypted and decrypted and getting incremented also. It seems to be a local problem.
Following URl will help you:
http://www.cisco.com/en/US/docs/security/vpn_modules/7100/6341/quick/guide/7100cf.html#wp1036101
141
