To automatically backup switches n routers config
cindylee27
Anybody knows about tools/free software that can use to backup the config remotely?
7 Replies 7
Pavel Bykov
Level 5
Level 5
You mean in a large group over SNMP?
Hi Slider,
Well, I mean if there is anyway that i can do a backup config all the network devices using any methods so tat at the end of the month, i will be able to get the configurations of each routers or switch.
Thanks.
CiscoWorks Resource Manager Essentials has a config archive utility which can automatically backup the startup & running config of numerous device types and vlan.dat if applicable.
It can use either snmp (RO/RW) or telnet/ssh to do this config backup.
Thanks Davis,
do you know of any free tools besides Cisco Works as we do not want to incur any costs ?
Thanks again.
we use NEDI. We use it for tracking config changes and syslog / snmp stuff. It keeps a track of all your configs in a mysql db also.
There is a free vmware application for it if you want to try it out quickly,
http://nedi.sourceforge.net/about.html
cheers
Richard
Kiwi Cat tools is another good choise for automated backups
RANCID may also be worth a look. This stores configs for multiple devices in a CVS repository allowing you to view the changes over time. It can also email notify on changes.
http://www.shrubbery.net/rancid/
