Community Member
tonton
hello i have problem with our CORE SWITCH 4006 we reset to factory default, and it was now not running the IOS..what should i do?
1 REPLY
Re: tonton
Which sup engine you are using. Please paste " show mod " from the switch.
Do you have a previous saved config file. If yes, then we can upload it to the switch.
Cat4006 runs CatOS with Sup2 sup engine. You can use the configuration guide below for configuring the switch.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/rel7_1/config/index.htm
HTH,
-amit singh
127
