Too high drop rate indication
I have a switch where if I run the command "show platform cpu packet statistics all" I see too high values for the "Input Acl" field and at that box there are no ACLs configured.
You can see that in the output below (look for the text in bold):
Switch#show platform cpu packet statistics all
Packets Dropped In Hardware By CPU Subport (txQueueNotAvail)
CPU Subport  TxQueue 0       TxQueue 1       TxQueue 2       TxQueue 3
           0               0               0               0       226280143
           1               0               0               0               0
           2               0            3493               0               0
           3               0               0               0               0
           4               0               0               0               0
           5               0               0               0               0
           6               0               0               0               0
           7               0               0               0               0
RkiosSysPacketMan:
Packet allocation failures: 0
Packet Buffer(Software Common) allocation failures: 0
Packet Buffer(Software ESMP) allocation failures: 0
Packet Buffer(Software EOBC) allocation failures: 0
Packet Buffer(Software SupToSup) allocation failures: 0
IOS Packet Buffer Wrapper allocation failures: 0
Packets Enqueued Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
                   0         0         0         0          0
Packets Not Enqueued Overall
                   0         0         0         0          0
Packets Dropped In Processing Overall
            30536158        27        19        20         20
Packets Not Enqueued by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Control Packet                       0         0         0         0          0
Input Acl                            0         0         0         0          0
RPF Fail                             0         0         0         0          0
Adjacency Same If                    0         0         0         0          0
L3 Forward                           0         0         0         0          0
NFL Copy To CPU                      0         0         0         0          0
Output Acl                           0         0         0         0          0
MTU Check Fail                       0         0         0         0          0
SA Miss                              0         0         0         0          0
L2 Forward                           0         0         0         0          0
SPAN                                 0         0         0         0          0
CPU Generated                        0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Dropped In Processing by CPU event
Input Acl                     30535609        27        19        20         20
RPF Fail                             0         0         0         0          0
SA Miss                            548         0         0         0          0
SPAN                                 0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Not Enqueued by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Unknown                              0         0         0         0          0
Normal                               0         0         0         0          0
Medium                               0         0         0         0          0
High                                 0         0         0         0          0
Crucial                              0         0         0         0          0
Super Crucial                        0         0         0         0          0
Packets Dropped In Processing by Priority
Unknown                              0         0         0         0          0
Normal                           25259         0         0         0          0
Medium                             549         0         0         0          0
High                          30510351        27        19        20         20
Crucial                              0         0         0         0          0
Packets Not Enqueued by Reason
Reason            Total                5 sec avg 1 min avg 5 min avg 1 hour avg
RxQueueNotAvail                      0         0         0         0          0
RxNoBuffersAvail                     0         0         0         0          0
RxBadCpuEvent                        0         0         0         0          0
Testing                              0         0         0         0          0
Packets Dropped In Processing by Reason
BadPddType                            0         0         0         0          0
VlanZeroBadCrc                        0         0         0         0          0
VlanZeroGoodCrc                       0         0         0         0          0
ReplVlan0GoodCrc                      0         0         0         0          0
NoPimPhyportMap                       0         0         0         0          0
NoPimPhyport                          0         0         0         0          0
UnimplementedEvt                      0         0         0         0          0
SrcAddrTableFilt                    547         0         0         0          0
NoL2Vlan                              0         0         0         0          0
STPDrop                               1         0         0         0          0
UnknownLyr-Bridge                     0         0         0         0          0
UnknownLyr-OutAcl                     0         0         0         0          0
L2DstDrop                             0         0         0         0          0
L2DstDropInAcl                        0         0         0         0          0
L2DstDropOutAcl                       0         0         0         0          0
AclNoVlan                             0         0         0         0          0
AclActionDrop                         0         0         0         0          0
AclActionRedirect                     0         0         0         0          0
AclActionUnsupptd                     0         0         0         0          0
UnknownBridgeAct                      0         0         0         0          0
NoTxInfo                              0         0         0         0          0
NoDstPorts                     30535609        27        19        20         20
NoFloodPorts                          1         0         0         0          0
ControlNoL2DstEnt                     0         0         0         0          0
InvalidAclAction                      0         0         0         0          0
AclInputErr                           0         0         0         0          0
OutAclEvntOnInAcl                     0         0         0         0          0
AclOutputErr                          0         0         0         0          0
ReservedPort                          0         0         0         0          0
EsmpNoTxInfo                          0         0         0         0          0
UnknownSource                         0         0         0         0          0
NoDriverTxPackets                     0         0         0         0          0
NoPimPort                             0         0         0         0          0
RouteLookupFailed                     0         0         0         0          0
FragPktAllocFailed                    0         0         0         0          0
IpHdrException                        0         0         0         0          0
SpanEvent                             0         0         0         0          0
Dot1xUnauthCtrlPkt                    0         0         0         0          0
No Sw port for ARP                    0         0         0         0          0
No Sw port for ESMP                    0         0         0         0          0
Total packet queues 16
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                                 0         0         0         0          0
L2/L3Control                 548361005        85        76        58         57
Host Learning                   245782         0         0         0          0
L3 Fwd High                          0         0         0         0          0
L3 Fwd Medium                   307222         0         0         0          0
L3 Fwd Low                    34926096         1         0         0          0
L2 Fwd High                          0         0         0         0          0
L2 Fwd Medium                        0         0         0         0          0
L2 Fwd Low                   226359049         5         0         1          3
L3 Rx High                           0         0         0         0          0
L3 Rx Low                            0         0         0         0          0
RPF Failure                          0         0         0         0          0
ACL fwd(snooping)                    0         0         0         0          0
ACL log, unreach                     0         0         0         0          0
ACL sw processing                    0         0         0         0          0
MTU Fail/Invalid                     0         0         0         0          0
Packets Dropped by Packet Queue
Esmp                                 0         0         0         0          0
L2/L3Control                      1839         0         0         0          0
Host Learning                     1675         0         0         0          0
L3 Fwd Medium                        0         0         0         0          0
L3 Fwd Low                         840         0         0         0          0
L2 Fwd Low                        2127         0         0         0          0
L3 Rx Low                            0         0         0         0          0
Packets Transmitted from CPU per Output Interface
Interface              Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Gi1/1                                0         0         0         0          0
Gi1/2                                0         0         0         0          0
Gi1/3                                0         0         0         0          0
Gi1/4                                0         0         0         0          0
Gi1/5                                0         0         0         0          0
Gi1/6                                0         0         0         0          0
Gi1/7                                0         0         0         0          0
Gi1/8                                0         0         0         0          0
Gi1/9                                0         0         0         0          0
Gi1/10                               0         0         0         0          0
Gi1/11                               0         0         0         0          0
Gi1/12                               0         0         0         0          0
Gi1/13                               0         0         0         0          0
Gi1/14                               0         0         0         0          0
Gi1/15                               0         0         0         0          0
Gi1/16                               0         0         0         0          0
Gi1/17                               0         0         0         0          0
Gi1/18                               0         0         0         0          0
Gi1/19                               0         0         0         0          0
Gi1/20                               0         0         0         0          0
Gi1/21                               0         0         0         0          0
Gi1/22                               0         0         0         0          0
Gi1/23                               0         0         0         0          0
Gi1/24                               0         0         0         0          0
Gi1/25                               0         0         0         0          0
Gi1/26                               0         0         0         0          0
Gi1/27                               0         0         0         0          0
Gi1/28                               0         0         0         0          0
Gi1/29                               0         0         0         0          0
Gi1/30                               0         0         0         0          0
Gi1/31                               0         0         0         0          0
Gi1/32                               0         0         0         0          0
Gi1/33                               0         0         0         0          0
Gi1/34                               0         0         0         0          0
Gi1/35                               0         0         0         0          0
Gi1/36                               0         0         0         0          0
Gi1/37                               0         0         0         0          0
Gi1/38                               0         0         0         0          0
Gi1/39                               0         0         0         0          0
Gi1/40                               0         0         0         0          0
Gi1/41                               0         0         0         0          0
Gi1/42                               0         0         0         0          0
Gi1/43                               0         0         0         0          0
Gi1/44                               0         0         0         0          0
Gi1/45                               0         0         0         0          0
Gi1/46                               0         0         0         0          0
Gi1/47                               0         0         0         0          0
Gi1/48                               0         0         0         0          0
Packets Received at CPU per Input Interface
Gi1/1                                0         0         0         0          0
Gi1/2                                0         0         0         0          0
Gi1/3                                0         0         0         0          0
Gi1/4                                0         0         0         0          0
Gi1/5                                0         0         0         0          0
Gi1/6                                0         0         0         0          0
Gi1/7                                0         0         0         0          0
Gi1/8                                0         0         0         0          0
Gi1/9                                0         0         0         0          0
Gi1/10                               0         0         0         0          0
Gi1/11                               0         0         0         0          0
Gi1/12                               0         0         0         0          0
Gi1/13                               0         0         0         0          0
Gi1/14                               0         0         0         0          0
Gi1/15                               0         0         0         0          0
Gi1/16                               0         0         0         0          0
Gi1/17                               0         0         0         0          0
Gi1/18                               0         0         0         0          0
Gi1/19                               0         0         0         0          0
Gi1/20                               0         0         0         0          0
Gi1/21                               0         0         0         0          0
Gi1/22                               0         0         0         0          0
Gi1/23                               0         0         0         0          0
Gi1/24                               0         0         0         0          0
Gi1/25                               0         0         0         0          0
Gi1/26                               0         0         0         0          0
Gi1/27                               0         0         0         0          0
Gi1/28                               0         0         0         0          0
Gi1/29                               0         0         0         0          0
Gi1/30                               0         0         0         0          0
Gi1/31                               0         0         0         0          0
Gi1/32                               0         0         0         0          0
Gi1/33                               0         0         0         0          0
Gi1/34                               0         0         0         0          0
Gi1/35                               0         0         0         0          0
Gi1/36                               0         0         0         0          0
Gi1/37                               0         0         0         0          0
Gi1/38                               0         0         0         0          0
Gi1/39                               0         0         0         0          0
Gi1/40                               0         0         0         0          0
Gi1/41                               0         0         0         0          0
Gi1/42                               0         0         0         0          0
Gi1/43                               0         0         0         0          0
Gi1/44                               0         0         0         0          0
Gi1/45                               0         0         0         0          0
Gi1/46                               0         0         0         0          0
Gi1/47                               0         0         0         0          0
Gi1/48                               0         0         0         0          0
Switch#
Can you please give me any idea why is it like that and what to do in order to eliminate this high drop rate?
Thanks in advance,
Vesko
2 ACCEPTED SOLUTIONS
Hellom
Input ACL does not necesarily means ACL configured on the interface. It can be any check whcih packet is passing on input. So by that counter we can see that there are many packets continiously hitting the CPU for some reason.
So we need to find what are those packets to undertsnad why they are processed (and not HW) switched. To do it you may need to do the follwoing CPU sniffer capture:
debug platform packet all count
show platform cpu packet statistics    - this command will show which interfaces are getting most of these packets
debug platform packet all receive buffer
show platform cpu packet buffered     - this command will show what are those packets
Then you can analyze the packets and see if you can stop those - possibly they belong to single host and you can trace it by the source MAC. Let us know if you will need help examing the packets.
Both debugs are not harmfull.
You can check following link for more references:
http://www.cisco.com/en/US/customer/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml#tool1
Hope this helps,
Nik
What you are checking by this command are the CPU queues. Packets are assigned with different priorities based on functions and thus treated differently by CPU. E.g control packets and some traffic are treated as High priority, ICMP treated as low priority.
Here you just see that traffic punted to CPU is treated by it as High priotiy and handled appropriately. It does not give us much - mostly the way CPU handles it internally.
P.S. I'm Russian
Nik
Hellom
Hope this helps,
Nik
Hi Nik,
thanks for the fast asnwer.
Can I also ask you to let me know how to interprete the high rate of drops from the "Packets Dropped In Processing by Priority" section:
Unknown                              0         0         0         0          0
Medium                             549         0         0         0          0
Crucial                              0         0         0         0          0
Thanks in advance.
Vesko
P.S. Btw, are you Bulgarian? :-)
P.S. I'm Russian
Nik
700
