03-19-2014 07:08 AM - edited 03-07-2019 06:46 PM
Hi !
We have a problem with switch connected to an IBM Chassis (model : WS-CBS3012-IBM-I).
Several links seem to flap from time to time and we have dropped packets (Outdiscards) :
XXX#show interfaces counters errors
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards
Gi0/7 0 0 0 0 0 43983
XXX#show controllers ethernet-controller gigabitEthernet 0/7
Transmit GigabitEthernet0/7 Receive
2584788113 Bytes 971769475 Bytes
2128747524 Unicast frames 2142250737 Unicast frames
10109338 Multicast frames 7644 Multicast frames
11694673 Broadcast frames 1660 Broadcast frames
0 Too old frames 991831483 Unicast bytes
0 Deferred frames 726180 Multicast bytes
0 MTU exceeded frames 106240 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 0 Minimum size frames
0 8 collision frames 208582465 65 to 127 byte frames
0 9 collision frames 286273443 128 to 255 byte frames
0 10 collision frames 15408397 256 to 511 byte frames
0 11 collision frames 12313490 512 to 1023 byte frames
0 12 collision frames 10599137 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 1609083109 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
320523 64 byte frames 0 Valid frames, too small
396763728 127 byte frames
6601722 255 byte frames 0 Too old frames
28139208 511 byte frames 0 Valid oversize frames
4064656 1023 byte frames 0 System FCS error frames
285633065 1518 byte frames 0 RxPortFifoFull drop frame
1429028633 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
The interface is Full-1000 and is configured :
interface GigabitEthernet0/7
description "SRV-001-PRD-VM1 - VMNic0"
switchport trunk allowed vlan 11,12,99
switchport mode trunk
link state group 1 downstream
end
For the "too large frames", I have already read the post : https://supportforums.cisco.com/discussion/11034901/too-large-frames-what-does-mean-performance, so, I think it's not serious.
But I don't know why some packets are dropped because the configuration seems good ...
Can you help me please ?
Thank you in advance !
11-12-2015 02:23 AM
Did you find an answer to this???
11-12-2015 02:54 AM
Hello PrinceMychkine,
did you try to change speed ?, becouse both the end of the interfaces should have same speed and duplex settings, try to check phyisical cabling also.
clear the interface and check again.
Ahmad Mestarihi
