Too many static routes
I have routers with very many static routes, many of which I suspect are no longer needed. Is there some command that will show the number of matches for each "ip route" statement? cf. show access-list for matches of ACLs. Does anybody know any other trick to remove unnecessary static route statements? Thank you.
1 REPLY
ovt Bronze
Bronze
Re: Too many static routes
ip cef
ip cef accounting per-prefix
show ip cef detail
For example:
0.0.0.0/0, version 60, epoch 0, cached adjacency xx.13.62.33
5 packets, 307 bytes
Flow: AS 0, mask 0
via xx.13.62.33, Vlan4, 0 dependencies
next hop xx.13.62.33, Vlan4
valid cached adjacency
HTH, rate if it does
134
