12-18-2006 10:50 AM - edited 03-05-2019 01:23 PM
I have a 6509 running IOS 12.2(18)SXD. I found a doc on Cisco's site that says that I should be able to run the Top command but I cannot. It does not exist. Nor does the Collect command. What am I missing here? Here is the link that tells me I should have the Top command. http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008043580b.html#wp1026365
12-18-2006 11:03 AM
Hi, I have used this command sparingly, but I believe it is only available with CAT OS and not IOS, of which you are running.
12-18-2006 01:38 PM
Yes that was what I thought too untill I did a search and found the document I referenced when I started the thread. It is a doc for configuring IOS on a 6509. It is for the verison I am running. It claims that the command should be there.
Thanks.
12-18-2006 01:45 PM
The command is available. I just tested on a 6509/SUP720 w/ 12.2(18)SXE4. Works great, thanks for bringing it up.
I originally thought it was ONLY for CATOS, but apparently it works for both.
CATOS: show top
IOS: (2 step process)
1. collect top ....
2. wait a few secs...
3. show top counter interface report 'x'
12-19-2006 06:28 AM
Yes my problem is that the "collect" command is not there. Neither is "Show Top".
12-19-2006 07:43 AM
Your linked document has the answer:
"Release 12.2(18)SXE and later releases support the Top N utility."
As you're only running 12.2(18)SXD you need to upgrade...
Andrew.
12-19-2006 09:49 AM
Well shoot! That's embarrasing. I did not catch the D of SXD. Thanks for pointing it out.
I will looking into upgrading as this will be a handy feature.
