05-22-2012 10:00 PM - edited 03-07-2019 06:51 AM
I have terminated the point to point link on 3550 switch.
Is there any way to obsreve top talkers on switch
on router i have excuted the command
ip flow-top-talkers
top 200
05-22-2012 10:26 PM
sh ip flow top
05-22-2012 11:08 PM
hey leo,
i've tried this on one our 1941 but i'm getting an error. do you know what i'm missing?
1941(config)#ip flow-top-talkers
1941(config-flow-top-talkers)#sort-by bytes
1941(config-flow-top-talkers)#cache-timeout 60000
1941(config-flow-top-talkers)#exit
1941(config)#int g0/1
1941(config-if)#ip flow ingress
1941(config-if)#ip route-cache
1941(config-if)#do show ip flow top
% Top talkers not configured
05-23-2012 12:04 AM
Hi John,
Did you configure "top 200" command on 1941?
Kind Regards,
Ivan
**Please grade this post if you find it useful.
05-23-2012 12:24 AM
whoops! i forgot that line. thanks! +5
i was following leo's thread and missed it.
05-23-2012 12:28 AM
Hi Ivan,
Is it supported on 3500 or 3750 ?
05-23-2012 12:39 AM
Hi Prashant,
3750 and 3560 switches do not support netflow, but there is a service module which can be inserted into 3750X and this supports Flexible Netflow (FNF). The commands are available but will not work unless the module is installed.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
The netflow support matrix can be seen in table 1 here:
Kind Regards,
Ivan
05-23-2012 12:29 AM
Glad it works, John :-) Thanks for rating the post.
